Static var inside a function
I need your help about the scope of a static ver (a memory) inside a function.
I have two modules:
module moduleWriter(input clock, input reset, input enabled);
module moduleReader(input clock, input reset, input enabled, output var[7:0] value);
Both of them uses a function which has a static variable inside:
function [7:0] memoryFunc(var opWrite, var[31:0] address, var[7:0] value = 0);
    static var [7:0] ram [0:1023];
    if (opWrite)
    begin
        ram[address] = value;
        return value;
    end
    else
        return ram[address];
endfunction
The ram variable wants to be a buffer written from several section of code.
In the attached example I aspect to have in output leds the value 30, but I get always 0. It seems the value rams is iniziled every time I called memryFunc.
Do you have an idea about what is wrong? I am using SystemVerilog and Vivado 2015.4, simulating a VC707 board.
Attached you can find a self consistent example.
Thank you
Michele Renda
I think I found the possible cause:
SystemVerilog has static and automatic tasks and functions. Vivado synthesis treats all tasks and functions as automatic.
http://www.xilinx.com/support/answers/51533.html
Anyone has a suggestion how can I workaround this? The other solution that comes to my mind is to pass the memory by ref, but Vivado System Verilog dialect does not support this too.
With the help of someone a bit more expert I found the right way to implement what I wanted. I post here the results to help other people with the same problem.
