Switch nets invisible in schematic view
it is possible to Switch off nets in the schematic view of Vivado? In my large design, I can see only a green area and finding of the modules is extreme difficult.
Thank you for your help.
BR
Martin sauer
Re: Switch nets invisible in schematic view
There is not a switch to turn off nets per se but you could do the following.
1) with the schematic open run "select_objects [get_nets]" in the Tcl console
2) Right click in the Schematic window and select "Remove selected items from Schematic"
This will remove the nets from the display and you can add them back as desired by double clicking on pins, expanding the cone etc ...
