olivierporchy
[Synth 8-5826] no such design unit <file> in library 'work'
Dear all
On a basic project with mixed vhdl and verilog files, when I launch 'synthesis' Vivado returns the error showed in the attached "capture0" file.
But a "report_compile_order" tcl command shows that the file is in the right library (see attached "capture" file).
Anybody to help me please ?
Olivier
olivierporchy
Thanks for answer.
Names match between verilog and vhdl.
It now works well. What I did is to declare the component in a vhdl wrapper that calls the verilog file...
TomH_BAH
My understanding of mixed language use is that VHDL instantiating Verilog is case sensitive. Double check the VHDL instantiation against the Verilog module name to make sure they match. If the file name is an indicator, the module is in all uppercase, where the error shows the instance is lowercase.
olivierporchy
Thanks for answer.
