barb.reveles
Synthesis Error: DRc 23-20 Rule Violation MDRV-1
So i keep getting this error about Multiple Driver Nets and i can't seem to locate the problem anywhere in my code. Can someone help me?
[DRC 23-20] Rule violation (MDRV-1) Multiple Driver Nets - Net h7/m8/Count/q_reg[16]_0 has multiple drivers: h7/m8/Count/q_reg[0]/Q, h7/m8/Count/q_reg[16]/Q
Here is all the modules that it mentions:
H7: Hex to SSD Decoder
module hex_ssd(clk, rst, Cathode,btn);
input clk, rst, btn;
output [7:0] Cathode;
reg [7:0] Cathode;
wire [3:0] HexVal;
mux m8 (.clk(clk),.rst(rst),.out(HexVal),.inVal(inVal),.val(btn));
always@(*)
    case(HexVal)
        4'h0: Cathode = 8'hc0;
        4'h1: Cathode = 8'hf9;
        4'h2: Cathode = 8'ha4;
        4'h3: Cathode = 8'hb0;
        4'h4: Cathode = 8'h99;
        4'h5: Cathode = 8'h92;
        4'h6: Cathode = 8'h82;
        4'h7: Cathode = 8'hf8;
        4'h8: Cathode = 8'h80;
        4'h9: Cathode = 8'h98;
        4'ha: Cathode = 8'h88;
        4'hb: Cathode = 8'h83;
        4'hc: Cathode = 8'hc6;
        4'hd: Cathode = 8'ha1;
        4'he: Cathode = 8'h86;
        4'hf: Cathode = 8'h8e;
        endcase
endmodule
m8: multiplexer
module mux( clk, rst, out, inVal,val);
input clk, rst,val;
input [15:0] inVal;
output [3:0] out;
reg [3:0] out;
wire [2:0] cathode;
wire [31:0] In;
assign In = {inVal[15:0],inVal[15:0]};
cathode cath(.clk(clk),.rst(rst),.cathode(cathode));
count32 Count(.clk(clk),.rst(rst),.count(val),.q(In));
always@(*)
    begin
        case(cathode)
            3'b000 : out = In[3:0];
            3'b001 : out = In[7:4];
            3'b010 : out = In[11:8];
            3'b011 : out = In[15:12];
            3'b100 : out = In[19:16];
            3'b101 : out = In[23:20];
            3'b110 : out = In[27:24];
            3'b111 : out = In[31:28];
        endcase
    end
endmodule
Count: 32-bit counter
module count32(clk, rst, count, q);
input clk, rst, count;
output [31:0] q;
reg [31:0] q;
wire inc;
button but(.clk(clk),.rst(rst),.button(count),.db(inc));
always@(posedge clk, posedge rst)
    if (rst) q <= 32'b0; else
    if (inc) q <= q + 32'b1;
endmodule
the 'q' is what the error is about but i don't see anything wrong with the always loop.
rshekhaw
Hi @barb.reveles ,
This message is informing you that there is a signal  that is being assigned / updated / driven in two different always blocks.
An example of a piece of code that would generate such an error is shown below:
always @ (posedge CLK)
y = y + 1;
always @ (posedge CLK2)
y = y + 3;
Solution:
It may be easier to use the elaborated netlist (RTL Analysis → Open Elaborated Design) to identify the signal by finding the signal in error using ctrl+F on open elaborated design.
Raj.
miker
I think your issue is that you are driving the 'In[31:0]' signal in "m8" by both the 'q' output of the "count32" module and in your top-level port 'inVal'.
m8: multiplexer
input clk, rst,val;
input [15:0] inVal;
output [3:0] out;
reg [3:0] out;
wire [2:0] cathode;
wire [31:0] In;
assign In = {inVal[15:0],inVal[15:0]}; -- Driving 'In' from both count32 instantiation 'q' output and with 'inVal' top-level port
always@(*)
    begin
        case(cathode)
        endcase
    end
endmodule
Please Reply, Kudos, and Accept as Solution.
anusheel
@barb.reveles
As already mentioned in the above post, there are two drivers for In. Please use the elaborated design to see the connection of In.
Anusheel
barb.reveles
“In” is supposed to come from the 32-bit counter which is why it’s driving into q, but the value “InVal” are the switches on the fpga, so how can I implement this without getting the error ?
barb.reveles
here is the elaborated design. "InVal" are the switches on the Nexys A7 board. However, i'm having trouble connecting the correct value to it. Each switch represents one of the 16 digits in the seven segment display. I tried connecting it to HexVal in my decoder but it also didn't work, could you help me?
