Synthesis Issue: ADC Deserializer
I'm curently designing a ADC controler to manage the serial data sent from a ADC (LTC2323-16) into a Zynq-7000, but timing failures poped up and we are trying to solve them.
One solution was changing the Verilog code of the deserializer block, following UltraFast Methodology's orientation.
Old code:
always @(posedge clk or posedge rx_reset)begin
    if(rx_reset)
		bit_index = msb_bit_index;
	else begin
		parallel_data[bit_index] = sdo;
		if(bit_index >= 1)
		 	bit_index = bit_index - 1;
	end
end
New code:
always@(posedge rx_reset) bit_index = msb_bit_index;
always @(posedge clk)begin
	if(bit_index >= 1)
end
The thing is, after the change, timing issues (mostly Hold) were greatly improved, but Post-Synthesis Functional Simulation went bad.
Behavioral Simulation (New Code):
Post-Synthesis Fuctional Simulation (New Code):
So I believe that Synthesis is messing up something, but can't quite know what.
I hope someone could give me some guesses or orientations.
Thanks in advance
Re: Synthesis Issue: ADC Deserializer
@matheusmpl91
The code mentioned in user guide talks about how to separate sync and async reset flops into separate process/always block, here you are using one always block to reset the flop and other always block to register the data, which looks incorrect to me and this is a case of multi-driver issue.
As you are facing timing related issues, better to start a new thread under Timing Analysis board with timing report of critical paths and also share the snapshot of the schematic. Also, try to use different implementation strategies and see if you can get better results.
Anusheel
@matheusmpl91
Are you referring to below section of UG949:
Anusheel
Yes, that's the one.
I ran a DRC Check and it pointed a multiple drivers issue when I split the block into two always blocks, because bit_index is being used in both ones, so it stays undefined.
The thing is, rx_reset is being treated as a asynchronous reset, but in fact is a well defined signal, genetared in another module by another clock:
always @ (posedge clk)
	if (count == trx_reseth)
		rx_reset <= 1'b1;
	else if (count == trx_reseth + rx_reset_length)
		rx_reset <= 1'b0;
	else
		rx_reset <= rx_reset;
Should I set it as false_path or try to define it as a generated_clock
Sorry if I'm making ingenuous questions... I'm new to Xilinx, Vivado and all this Digital Systems Design universe.
Thanks for the patience and for the assistance
@matheusmpl91
Anusheel
