Scholar richardhead
Synthesis doesnt know difference between downto and to
There is a bug where if you map an aggregate in a port map using an unconstrained array (or record type) it maps the arrays by index, rather than taking into account the direction of the array against VHDL rules.
In the following code, IP0 should ultimately connect to OP0, and IP1 -> OP1
But alas no, IP0 -> OP1 and IP1 -> OP0
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
package pkg is
type slv_array_t is array(natural range <>) of std_logic_vector;
end package pkg;
library ieee;
use work.pkg.all;
entity ent is
generic (
N : natural := 2
port (
ip : in slv_array_t(N-1 downto 0); -- stll unconstrained
op0 : out std_logic_vector;
op1 : out std_logic_vector
end entity ent;
architecture rtl of ent is
begin
op0 <= ip(0);
op1 <= ip(1);
end architecture rtl;
library ieee;
use work.pkg.all;
entity top is
port (
ip0 : in std_logic_vector(7 downto 0);
ip1 : in std_logic_vector(7 downto 0);
op0 : out std_logic_vector(7 downto 0);
op1 : out std_logic_vector(7 downto 0)
end entity top;
architecture rtl of top is
begin
inst : entity work.ent
generic map (
N => 2
port map (
ip => (ip1 & ip0),
op0 => op0,
op1 => op1
And here is the elaborated design:
Let me explain what is going on:
ent has an input port decalred (N-1 downto 0).
In the port mapping, I create an aggregate (ip1 & ip0).
In VHDL, this defaults (0 to 1), but the port its mapping to is (1 downto 0). So mapping should be 0 -> 1 and 1 ->0 as per VHDL rules.
Unfortunately Vivado seems to think It can connect 0 -> 0 and 1 -> 1. This is NOT how VHDL mapping works, hence an elaboration bug.
Re: Synthesis doesnt know difference between downto and to
Hi @richardhead,
I am looking into your source code. I will get back to you with the outcomes.
hemangd
hemangd
Scholar richardhead
If I change the code to be more 1993 style (code still set as VHDL 2008), it works as expected. Only change is:
type slv_array_t is array(natural range <>) of std_logic_vector(7 downto 0);
Elaboration is:
So I assume this is a difference in the way Vivado is handling 2008 unconstrained arrays (and records, because in my real code I have an array of records as a port - and it also exhibits the same issue as #1)
Scholar richardhead
@hemangd
Any update on this?
@richardhead
I used the code posted in your first reply and ran it in 2018.2 and I don't see any issue. Please let me know which version of Vivado you are using or if I missed anything.
Anusheel
Scholar richardhead
@anusheel
You have exactly the same problem as me. IP0 should connect to OP0, but it doesnt - it connect to OP1
Scholar richardhead
@anusheel
This is Vivado 2018.2
As you have shown, you are seing the same problem as me (please look at the paths all the way through the diagram). If you modify the type in the package (no other code mods), as per #3, the problem goes away (as I show in the picture inn #3, IP0 -> OP0, and IP1 -> OP1). This appears to be a bug in the way Vivado interprets VHDL2008 aggregates when done in a port map.
Scholar richardhead
@anusheel @hemangd
What is the status on reporting this bug?
@richardhead
I have filed a CR for this issue.
Anusheel
Scholar richardhead
@anusheel
Can you confirm if this has been fixed in the preview vivado builds? (I assume 2019.1)
@richardhead
This CR is still under investigation. We should have some update on this CR in coming weeks.
Anusheel
Scholar richardhead
@anusheel
Do you have an update on this CR?
@richardhead
This issue is now fixed for future major releases.
Anusheel
