stendek
Synthesis error in ISE 7.1i. Help please!
Hi.
I have compiled the different source files of my ISE project, but when I proceed to synthesize them, two error messages appear.
The error messages are:
ERROR:HDLParsers:340 - "F:/Sanchez/Aritmetica/FDTDv1-enteros/tipos.vhd" Entity <mainfdtd> does not exist in library <work>.
ERROR:Xst:1867 - Entity <mainfdtd> not found, Recompile it.
No matter if I try to synthesize a component source or the main source (mainfdtd), the same error messages appear. However, it seems to me rather strange, because the "tipos.vhd" source is a VHDL package file.
stendek
Hi.
I have solved the problem, although I don't know the reason why this was an error.
I just deleted the tipos.vhd file from my project and everything worked.
But the tipos.vhd file contains a package with constants and type definitions, and the rest of files in the project include a "use work.tipos" clause, so I don't understand why this file must be taken away from the project.
Jose from University of Alicante, Spain.
eilert
if your file contains both, entity and architecture, the most possible cause seems to be some simple typo.
there are only three lines wher the entity name appears (aside from configuration stuff)
entity xxx is
end xxx;
architecture yyy of xxx is
Carefully reread these lines, or let someone else do it.
mainfdfd
mainfdtd
maintdtd
looks all very much the same for the human eye. ;-)
Have a nice synthesis
  Eilert
stendek
Hi.
eilert
Hi Jose,
a package is not a synthesizable model.
Maybe that's why you got the strange error message.
Check your synthesis report, and you probably see some info about processing the package file tipos.vhd.
Also, removing a file from the sources window does not mean, that it's also deleted from the library window, so it may still be part of your project, but no longer be assumed to contain a synthesizable model.
  Eilert
bassman59
Historian
Historian
eilert wrote:
Hi Jose,
I use packages all the time with synthesizable code. Perhaps the ancient 7.1 tools have issues with them?
