Synthesis failed without reporting any error
Here is the log when I hit run synthesis in Vivado 2015.4
*** Running vivado
with args -log aes_encrypt.vds -m64 -mode batch -messageDb vivado.pb -notrace -source aes_encrypt.tcl
****** Vivado v2015.4 (64-bit)
**** SW Build 1412921 on Wed Nov 18 09:44:32 MST 2015
**** IP Build 1412160 on Tue Nov 17 13:47:24 MST 2015
** Copyright 1986-2015 Xilinx, Inc. All Rights Reserved.
source aes_encrypt.tcl -notrace
Command: synth_design -top aes_encrypt -part xc7k70tfbv676-1
Starting synth_design
Attempting to get a license for feature 'Synthesis' and/or device 'xc7k70t'
INFO: [Common 17-349] Got license for feature 'Synthesis' and/or device 'xc7k70t'
INFO: Launching helper process for spawning children vivado processes
INFO: Helper process launched with PID 9855
Starting Synthesize : Time (s): cpu = 00:00:06 ; elapsed = 00:00:06 . Memory (MB): peak = 1047.977 ; gain = 193.707 ; free physical = 88 ; free virtual = 28405
INFO: [Synth 8-638] synthesizing module 'aes_encrypt' [/home/agohil/proj/block2tests/src/dsn/aes_encrypt.sv:3]
Parameter Nk bound to: 4 - type: integer
Parameter Nr bound to: 10 - type: integer
INFO: [Synth 8-638] synthesizing module 'aes_key_expand' [/home/agohil/proj/block2tests/src/dsn/aes_key_expand.sv:3]
INFO: [Synth 8-256] done synthesizing module 'aes_key_expand' (1#1) [/home/agohil/proj/block2tests/src/dsn/aes_key_expand.sv:3]
INFO: [Synth 8-638] synthesizing module 'aes_cipher' [/home/agohil/proj/block2tests/src/dsn/aes_cipher.sv:4]
INFO: [Synth 8-256] done synthesizing module 'aes_cipher' (2#1) [/home/agohil/proj/block2tests/src/dsn/aes_cipher.sv:4]
INFO: [Synth 8-256] done synthesizing module 'aes_encrypt' (3#1) [/home/agohil/proj/block2tests/src/dsn/aes_encrypt.sv:3]
Finished Synthesize : Time (s): cpu = 00:00:12 ; elapsed = 00:00:13 . Memory (MB): peak = 1192.500 ; gain = 338.230 ; free physical = 104 ; free virtual = 28257
Finished Constraint Validation : Time (s): cpu = 00:00:13 ; elapsed = 00:00:13 . Memory (MB): peak = 1192.500 ; gain = 338.230 ; free physical = 104 ; free virtual = 28257
Start Loading Part and Timing Information
Loading part: xc7k70tfbv676-1
Finished Loading Part and Timing Information : Time (s): cpu = 00:00:13 ; elapsed = 00:00:13 . Memory (MB): peak = 1200.500 ; gain = 346.230 ; free physical = 104 ; free virtual = 28257
INFO: [Device 21-403] Loading part xc7k70tfbv676-1
Finished RTL Optimization Phase 2 : Time (s): cpu = 00:00:28 ; elapsed = 00:00:25 . Memory (MB): peak = 1323.254 ; gain = 468.984 ; free physical = 111 ; free virtual = 28148
Report RTL Partitions:
| |RTL Partition |Replication |Instances |
No constraint files found.
Start RTL Component Statistics
Detailed RTL Component Info :
+---XORs :
3 Input 32 Bit XORs := 1
2 Input 32 Bit XORs := 74
4 Input 32 Bit XORs := 1
5 Input 32 Bit XORs := 1
6 Input 32 Bit XORs := 1
7 Input 32 Bit XORs := 1
8 Input 32 Bit XORs := 1
9 Input 32 Bit XORs := 1
10 Input 32 Bit XORs := 1
11 Input 32 Bit XORs := 1
12 Input 32 Bit XORs := 1
2 Input 8 Bit XORs := 216
4 Input 8 Bit XORs := 144
+---Registers :
128 Bit Registers := 11
8 Bit Registers := 150
1 Bit Registers := 11
+---ROMs :
ROMs := 150
Finished RTL Component Statistics
Start RTL Hierarchical Component Statistics
Hierarchical RTL Component report
Module aes_key_expand
+---XORs :
2 Input 32 Bit XORs := 30
Module aes_cipher
+---XORs :
2 Input 32 Bit XORs := 44
+---Registers :
+---ROMs :
ROMs := 150
Finished RTL Hierarchical Component Statistics
Start Part Resource Summary
Hi @qubits1
I suspect the issue here is unsupported OS.
Can you check run synthesis on the same project on a supported OS. Check the following user guide for supported OS: http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug973-vivado-release-notes-install-license.pdf
Vinay
There is one more line in the log.
Parent process (pid 9847) has died. This helper process will now exit
I'm running this in Ubuntu 15.10
Hi @qubits1
Vinay
@qubits1
Ubuntu 15.10 is not supported with Vivado. Try to use supported OS and see if you are able to pass the synthesis phase.
Anusheel
Search for documents/answer records related to your device and tool before posting query on forums.
Search related forums and make sure your query is not repeated.
Please mark the post as an answer "Accept as solution" in case it helps to resolve your query.
Helpful answer -> Give Kudos
I just ran into this error as well on Ubuntu 15.10. Is Ubuntu 16.04 support coming? It's an LTS release so many will be upgrading.
I am running on a Windows machine (supported OS) and I get the same type of failure.
Here is the end of my log
Part Resources:
DSPs: 120 (col length:60)
BRAMs: 150 (col length: RAMB18 60 RAMB36 30)
Finished Part Resource Summary
INFO: [Synth 8-5580] Multithreading enabled for synth_design using a maximum of 2 processes.
Start Parallel Synthesis Optimization  : Time (s): cpu = 00:01:37 ; elapsed = 00:01:48 . Memory (MB): peak = 862.031 ; gain = 690.270
I will continue searching for a solution
