Visitor pradeepreddy
Synthesis of Block Design wrapper
Did the synthesis flow in vivado 2017.2 for the creating Block Diagram in the following steps
1. Created Project
2. Created Block diagram
3. Added RTL Files
4. Added RTL Module to the Block Diagram
5. Integrated RTL with IP Core.
6. Generated Block Design
7. Validated Design
8. Created HDL Wrapper
9. Saved Design
10. Run Synthesis.
But when running the synthesis, i did see args in the log file for synthesis command is <rtl_top_module>.tcl instead of <wrapper_bd>.tcl
So it is doing synthesis for only rtl top but not block design wrapper
Do i miss any steps in the process of this.
Please let me know.
Re: Synthesis of Block Design wrapper
Hi @pradeepreddy
Ideally it should show <wrapper_bd>.tcl in the args in the log file as long as your wrapper is set as top. Is your wrapper file set as top?
The steps being followed looks correct to my knowledge. Can you show the source hierarchy of your project?
Rohit
Rohit
Hi @pradeepreddy
Rohit
Rohit
