ultragreen
Synthesis process stucks after 2 hours xx mins
I am facing this  issue  from last few days, The design starts synthesizing and after completing 2 hours it gets stuck, it does not give  any critical warning or errors, no addition in log file and even after many hours the elapsed time shows 2 hours 08 mins. I killed the process and ran it thrice, but every time , after synthesizing 2 hours and few mins - no updation in log files and elapsed time stuck at the same value although other windows of vivado are active and I can access them. for further clarification, Please find the attached snapshots.
anusheel
@ultragreen
As a rule of thumb disable multi threading whenever you get any crash issues. Refer below link:
http://www.xilinx.com/support/answers/52905.html
http://www.xilinx.com/support/answers/50345.html
In which phase synthesis engine was stuck? Share the synthesis log here. Also, did you try the -flatten_hierarchy to "none"  before launching the synthesis?
Anusheel
Helpful answer -> Give Kudos
florentw
Hi @ultragreen,
Can you try with a different synthesis strategy?
Florent
Florent
balkris
are you able to synthesis other designs. check with other code . if designing failing with all the code it may be installation issue.
Update your Vivado version with Vivado 2016.2 release
You may share your project so i can run locally here
Thanks and Regards
Balkrishan
ultragreen
I won't be able to share the project, but I am trying with other synthesis strategy.
Also I am trying to run on different server.
Also I wanted to ask, if there any problem with the design, shouldn't it be throwing some error or warining ?
If the changing strategy and server doesn't work then I will try installing 2016 version.
Please let me know if anything else I can try .
florentw
Hi @ultragreen,
Which version of Vivado are you using?
Changing the strategy to the default one is usually a good thing to try first. So we will wait to see if you can complete the synthesis with this set.
Florent
ultragreen
vivado 2015.4.1
anusheel
@ultragreen
Anusheel
ultragreen
I set it as rebuild. It was getting stuck on different phases every time. But the problem got resolved as I moved my design to different server. It looks like some memory issue in that machine. Thanks
