Synthesis with gated clock conversion crashes
Hello!
Synthesis operation crashes, outputting following messages:
[INFO] Looking for combinational gated clock conversion opportunities (AND/OR/NAND/NOR) on gated clock 'n_0_689'
Doing HARTGatedClock::extractGatedClockEnableWithNlopt
Abnormal program termination (11)
Please check '/home/bud/projects/AmalteaFpgaDirk/mlx75320BA/digital/processing/fpga/hs_err_pid11308.log' for details
bash-4.1$ Parent process (pid 11308) has died. This helper process will now exit.
hs_err_pid11308.log is attached
There is no net n_0_689 in synthesized design with neither rebuilt nor full flatten hierarchy.  How can i determine which place in design causes error to work around it?
Bogdan
Hi @bud_melexis
Is it possible to share testcase to further debug this issue?
Hello Manusha,
Unfortunately i can't share project RTL until there NDA is not signed.
Bogdan
Is this ASIC design for FPGA prototyping? Or you have designed this only for FPGA?
If it's only FPGA specific then I guess it's better to avoid clock gating using combination logic, you can use the UG949 to handle better clock gating using proper clock buffers.
Yash
@bud_melexis
To avoid crash, try to change the flatten_hierarchy to none.
Also, if you can debug and understand at which module this issue got triggered then put a KEEP_HIERARCHY attribute to that module to block clock conversion and see if tool completes synthesis.
Also, what happens when you disable gated clock conversion under synthesis settings?
Anusheel
  Can you try with 2017.3. I see the design was run with 2017.2
Nithin
Hi There is a bug with the synthesis tool which means that your synthesis may crash.
As an ASIC to FPGA engineer I have suffered many hours of wasted time due to problems with synthesis tool not dealing well with gated clock latches.
Please see this post I have just written.
https://forums.xilinx.com/t5/Synthesis/Synthesis-Bug-Vivado-Synthesis-Tool-fails-during-gated-clock/td-p/822426
Cheers Simon
@simonh_bwt
I can see that @pulim is already working on this reported crash issue. Thanks for reporting this issue.
Anusheel
