[SystemVerilog] MUX Inference from Indexing `automatic` Array Broken
While simulation works properly, the Vivado synthesis engine fails on inferring an intact MUX for indexing an `automatic` array.
This issue can be confirmed with Vivado 2020.1 with this example:
// Plain 4:1-MUX with named inputs a, b, c, d
module mux #(
	type T = logic
	input	logic clk,
	input	logic [1:0] s,	// Select
	input	T a, b, c, d,	// Data Inputs
	output	T y				// Data Output
	always_ff @(posedge clk) begin
		automatic T	src[4] = '{ 0: a, 1: b, 2: c, 3: d };
		y <= src[s];
	end
endmodule : mux
// Quick Testbench
module mux_tb;
	typedef logic T;
	logic clk = 0;
	always #5ns clk = !clk;
	// DUT
	struct packed {
		logic	[1:0]	s;
		T		[3:0]	x;
	} i;
	T	y;
	mux dut(
		.clk,
		.s(i.s),
		.a(i.x[0]), .b(i.x[1]), .c(i.x[2]), .d(i.x[3]),
		.y
	// Stimuli
	initial begin
		i = $urandom(42);
		repeat(100) begin
			@(posedge clk); #1ns;
			$display("%0d of %04b -> %0x", i.s, i.x, y);
			assert(y == i.x[i.s]) else begin
				$error("Output mismatch.");
				$stop;
			end
			i <= $urandom();
		end
		$finish;
	end
endmodule : mux_tb
While simulating `mux_tb` encounters no error, the synthesis will produce a severely impaired result completely ignoring three out of the four possible source inputs:
Hi @preusser ,
This looks to the issue with tool with automatic variable declaration. I will investigate this further and report the issue to get fixed in future release.
-Shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
Hi @preusser
Slight correction- The issue is with unpacked type variable declaration inside procedural context (with or without automatic keyword). Have reported the issue to fix in later release.
Shreyas
