Observer roader
Understanding how blocking and non blocking statements work in this AXI4 interface
I am looking at a small AXI4 interface block and am trying to understand how the synthesis tool handles the always@* logic and what it actually synthesizes to.
This is what the code which I am going through looks like.
always @* begin
    write = 1'b0;
    wr_ptr_next = wr_ptr_reg;
    wr_ptr_gray_next = wr_ptr_gray_reg;
    if (s00_axis_tvalid) begin
        // input data valid
        if (~full) begin
            // not full, perform write
            write = 1'b1;
            wr_ptr_next = wr_ptr_reg + 1;
            wr_ptr_gray_next = wr_ptr_next ^ (wr_ptr_next >> 1);
        end
    end
end
always @(posedge s00_axis_aclk) begin
    if (s00_rst_sync3_reg) begin
        wr_ptr_reg <= {ADDR_WIDTH+1{1'b0}};
        wr_ptr_gray_reg <= {ADDR_WIDTH+1{1'b0}};
    end else begin
        wr_ptr_reg <= wr_ptr_next;
        wr_ptr_gray_reg <= wr_ptr_gray_next;
    end
    wr_addr_reg <= wr_ptr_next;
    if (write) begin
        mem[wr_addr_reg[ADDR_WIDTH-1:0]] <= mem_write_data;
    end
end
The code is taken from alex forencich's github repository located here https://github.com/alexforencich/verilog-axis.
The above snippet is trying to generate the write address for the RAM. I am still a little confused as to how the always@* synthesized to. In the above example each time the block is entered write is set to 0, then write pointer next is incremented and the incremented value is used to generate the gray code address. Could someone explain how the always@* logic works? What is it synthesizing to in hardware?
Re: Understanding how blocking and non blocking statements work in this AXI4 interface
Well, you can synthesize it in Vivado and have a look..
But in general, the always @* will create combinational logic... so ANDs and ORs and not flip-flops.
The "if" statements will produce something equivalent to a mux.
Not sure if this helps, but it's equivalent to this (slightly more hardware looking) snippet:
wire  mux_select = s00_axis_tvalid & (~full);
wire write = (mux_select==1)? 1 : 0 ; wire wr_ptr_next = (mux_select==1)? wr_ptr_reg + 1 : wr_ptr_reg; wire wr_ptr_gray_next = (mux_select==1)? wr_ptr_next^(wr_ptr_next>>1) : wr_ptr_gray_next;
Observer roader
That makes sense. Thanks a lot.
