taichi730
Unexpected "[Synth 8-6038]" and "[Synth 8-660]" errors
When I tried to synthesis RTL with a function having following characteristics I got unexpected "[Synth 8-6038]" and "[Synth 8-660]" errors.
Characteristics of function:
  • Defined in interface
  • Function name is same as system function
    • function name: countones
    • system function name: $countones
This is a sample code to reproduce this problem.
interface foo_if;
  function logic countones(logic v);
    return v;
  endfunction
endinterface
module top(
  input   logic i_clk,
  input   logic i_rst_n,
  input   logic i_d,
  output  logic o_d
  foo_if foo();
  always_ff @(posedge i_clk, negedge i_rst_n) begin
    if (!i_rst_n) o_d <= '0;
    else          o_d <= foo.countones(i_d);
  end
endmodule
Synthesize the above code then you will see error messsages below.
[Synth 8-6038] cannot resolve hierarchical name for the item 'foo' ["/home/ishitani/workspace/test/func_name/func_name.sv":17]
[Synth 8-660] unable to resolve 'countones' ["/home/ishitani/workspace/test/func_name/func_name.sv":17]
Function name is changed to different name, e.g. countones -> __countones, then this sample code can be synthesized.
I think this storange behavior is caned by Vivado's bug.
Taichi Ishitani
apetley
Its not advisable to have same name of functions as that of system functions.
Coming to issue, yes vivado needs to fix this. Will raise a CR to get this fixed.
Ajay
apetley
Ajay
taichi730
Hi @apetley ,
Thank you for filing CR for this issue.
Taichi Ishitani
