2U3
Using module to fail in SystemVerilog
It works well with a code in "CASE 1" shown below, during button being pressed LED is on, but "CASE 2."
Could anyone please show me why and how to correct?
Thank you.
================================================ CASE 1
`timescale 1ns / 1ps
// btn_led.sv
// Create Date: 12/30/2020 01:39:00 AM
module btn_led (
input logic IN_CLK, IN_BTN,
output logic OUT_LED
reg led = 1'd1;
assign OUT_LED = led;
reg xxx = 1'd0;
always @(posedge IN_CLK) begin
if (IN_BTN) begin
led <= 1'd0;
end else begin
led <= 1'd1;
end
end
btn_led_sub # (
.CNT_X(868))
ser (
.IN_CLK(IN_CLK),
.IN_BTN(IN_BTN),
.OUT_LED(xxx));
//.OUT_LED(led));
endmodule
================================================ CASE 1 (END)
================================================ CASE 2
// btn_led.sv
module btn_led (
reg led = 1'd1;
reg xxx = 1'd0;
if (IN_BTN) begin
led <= 1'd0;
end else begin
led <= 1'd1;
end
end
btn_led_sub # (
.CNT_X(868))
ser (
.IN_CLK(IN_CLK),
.IN_BTN(IN_BTN),
//.OUT_LED(xxx));
.OUT_LED(led));
endmodule
================================================ CASE 2 (END)
// btn_led_sub.sv
// Create Date: 12/30/2020 01:49:22 AM
module btn_led_sub(
parameter CNT_X = 32'd124999999; // 125MHz clk for 1sec
reg led = 1'd1;
if (IN_BTN) begin
led <= 1'd0;
end else begin
led <= 1'd1;
end
end
endmodule
viviany
What problem do you have with Case2?
I see a mistake in the code for case2.
You should remove this line in btn_led module:
reg led = 1'd1;
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
viviany
reg led = 1'd1;
-vivian
2U3
The problem was that during a button being pressed an LED is still off in case 2, while an LED is on in case 1.
Then, removing the line makes the LED being on in case 2, it is behavior being intended.
Thank you for very helpful answer.
