[VHDL] Record of Record
Is there any way to create a record of another record in VHDL?
Suppose that I have a record of 4 registers:
    type registers_record is record
        register_0  : std_logic_vector(31 downto 0);
        register_1  : std_logic_vector(31 downto 0);
        register_2  : std_logic_vector(31 downto 0);
        register_3  : std_logic_vector(31 downto 0);
    end record;
And register_0 has some bitfields, e.g. bit-31 is pll_lock, [30:21] is cnt_limit and [20:0] is latency,
    type register_0 is record
        pll_lock    : std_logic;
        cnt_limit   : std_logic_vector(9 downto 0);
        latency     : std_logic_vector(20 downto 0);
    end record;
And I would like to do this in my actual RTL:
signal regs_record : registers_record;
signal mmcm_lock : std_logic := '0'; -- connected to an MMCM pin regs_record.register_0.pll_lock <= mmcm_lock;
Which of course, gives me an error.  What am I doing wrong?
Re: [VHDL] Record of Record
A record is just a composite type - each field can be any type. So you can nest records inside records.
So you can decalre like this:
type register_0_t is record
end record;
type register_record_t is record
  register_0  : register_0_t;
  register_1 : register_1_t;
end record;
regs.register_0.pll_lock <= mmcm_locked;
end record;
end record;
Hi @cbakal
Define record type for the elements of register_0 first and then use that as element type in your registers_record.
for example,
type rec1 is record
end record;
register_0 : rec1;
register_1 : rec1;
register_2 : rec1;
register_3 : rec1;
end record;
