richardhead
[VHDL2019 Feature Request] Interfaces
VHDL 2019 adds Interfaces, similar to interfaces and modports in SV, which are already supported.
An example of a VHDL 2019 Interface is:
-- A FIFO like streaming interface:
type StreamingIf is record
  Valid  : Std_uLogic;
  Data   : Std_uLogic_Vector(7 downto 0);
  Ack    : Std_uLogic;
end record StreamingIf;
view MasterView of StreamingIf is
   Valid : out;
   Data  : out;
   Ack   : in;
end view MasterView;
alias SlaveView is MasterView'CONVERSE;
-- Equivalent mode view declaration
-- view SlaveView of MasterView is
--    Valid : in;
--    Data  : in;
--    Ack   : out;
-- end view SlaveView;
-- A stream processing element
entity SPE is
  port (
    Clock  : in   Std_uLogic;
    Reset  : in   Std_uLogic;
    Input  : view SlaveView;   -- input from previous SPE
    Output : view MasterView   -- output to next SPE
end entity;
And then, port mapping can simply be done like this:
signal loopback_connect : StreamingIf;
inst : entity work.SPE
port map (
  Clock => Clock,
  Reset => Reset,
  Input => loopback_connect,
  Output => loopback_connect
