Variable assignment inside a VHDL process in Synthesis
Hi all,
I'm a newbie in VHDL design. I have a doubt regarding different assignations to the same variable inside a process in a post-synthesized design.
For example the next code snippet:
--previous code
p1 : process (clk,reset)
  variable a : std_logic;
  variable b : std_logic;
begin
  a := '1'
 --some code here that modifies b variable
  if ( b = '1') then
    a := '0';
  end if;
end process;
--the code goes on
Can it be assured that during execution in FPGA, if b is '1', a always will be '0'. In other words, I know that during simulation all statements inside a process are executed sequentially, but can we say the same in relation to a synthesized design? Is the execution order inside the process sequential too?
Thanks!
Professor
Professor
Re: Variable assignment inside a VHDL process in Synthesis
Yes.  It has to work that way to be at all useful.  Otherwise variables would be for simulation only.
-- Gabor
Ok, thanks for the anwser.
But why should variables be for simulation only? I'm using variables in a combinational process. At the beginning I update them with the value of some signals and at the end I register them into the same signals. I'm using the two process methodology from Gaisler.
Professor
Professor
What I meant was that if Synthesis doesn't behave the same for variables as Simulation, then variables wouldn't be useful for synthesis.
-- Gabor
