Visitor karahanli
Vhdl with VGA Controller
Good day,
I did it with Vga control, but I'm trying to create a color palette.I have encountered such an error. I don't understand how I'm making mistakes at replacements. Thanks for your help.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
USE ieee.numeric_std.ALL;
use ieee.numeric_std.all;
--use IEEE.STD_logic_ARITH.all;
 use ieee.std_logic_unsigned.all;
 use ieee.std_logic_signed.all;
entity VGA_Test is
    generic(RGBLength : integer := 1);
    port(Clk : in std_logic;                                    --Clk girişi
        R, G, B : out std_logic_vector(RGBLength - 1 downto 0);  --VGA R, G, B sinyalleri
        HSync, VSync : out std_logic);                           --VGA HSync, VSync sinyalleri
end VGA_Test;
architecture Behavioral of VGA_Test is
--VGA sürücü componenti
component vga_pll
    generic(RGBLength : integer := 1);                               --R, G, B sinyallerinin genişliği
        --(Renk derinliği)
        X, Y : out std_logic_vector(15 downto 0);                     --X,Y koordinatları
        --Bu sinyaller o an hangi pixelin DAC'ye
        --gönderileceğini belirtir.
        Rin, Gin, Bin : in std_logic_vector(RGBLength - 1 downto 0);  --R, G, B bilgileri
        --Okunan X, Y sinyallerine göre istenen
        --RGB verisi bu sinyaller tarafında gönderilir.
        --Monitöre giden sinyaller
        R, G, B : out std_logic_vector(RGBLength - 1 downto 0);       --DAC'ye gönderilercek RGB sinyalleri
        HSync, VSync : out std_logic);                                --Yatay ve Dikey senkronizasyon sinyalleri
end component;
    signal Xs, Ys : std_logic_vector(15 downto 0);
    signal X, Y : integer range 0 to 2**20-1;
    signal Rin, Gin, Bin : std_logic_vector(0 downto 0);
begin
    --Xs, Ys sinyalleri integer'a dönüştürülür
    X <= to_integer(unsigned(Xs));
    Y <= to_integer(unsigned(Ys));
    VGADriver : vga_pll
        generic map(1)
        port map(Clk => Clk, X => Xs , Y => Ys, Rin => Rin , Gin => Gin, Bin => Bin , R => R , G => G, B => B, HSync => HSync, VSync => VSync);
    process(X, Y)
    begin
        --Renk Paleti
        Bin(0) <= std_logic_vector(to_unsigned(X / 160, 3))(0);
        Gin(0) <= conv_std_logic_vector(to_unsigned(X / 160, 3))(1);
        Rin(0) <= conv_std_logic_vector(to_unsigned(X / 160, 3))(2);
    end process;
end Behavioral;
Teacher drjohnsmith
Re: Vhdl with VGA Controller
I agree,
thats a problem,
   can i suggest, may be not, may be so,  that you look at the hen book, and once the golden egg of understanding has been laid,
      then more scrambled not will be the results,
yoda him say,
What error are you seeing?  Did you simulate?
Visitor karahanli
I'm sory. I forgot to write the error. Error related to variables.
You don't need
the numeric_std library includes everything you need for this code.  The synthesis tool does not know which definition of to_unsigned to use.
Visitor karahanli
Thank you but again there is error. I write according to the rules but did not. I do not understand.image.png
Teacher drjohnsmith
sorry,
you hav emodified you rcode, and then shown us a little bit of it, and said there is an error,
  Can you post you rcode as an attatchment please,
  Im detecting your learning VHDL,
can I suggest you need a better book,
here are some ( IMHO ) usefull links,
http://www.bitweenie.com/listings/vhdl-type-conversion/
http://freerangefactory.org/
https://www.nandland.com/articles/std_logic_arith_vs_numeric_std.html
Scholar richardhead
@karahanli
You have included numeric_std twice, importing all the types twice, making anything in them invisible.
You have also included std_logic_signed and unsigned, also making most of both libraries invisible (as they define the same functions on the same types)
Only include the library once. And preferably remove the std_logic_signed and unsigned pakcages (as they are not standard VHDL).
Teacher drjohnsmith
I did not relalise including the same library twice caused problems.
Th ecode does need some serious mentoring on it though
Scholar richardhead
@drjohnsmith
Neither did I - but given the OP has only posted this one code, I can only see that as the problem.
Unless they are compiling code that hasnt been posted, and has numeric_std and std_logic_arith included, which is the usual source of this error.
If you blow up the screenshot of the OP's last post, you see a different error "Cannot index the results of a type conversion."
First, you have no variables in any of the code you posted.  You have signals.  They are very different.
I think you have X and Y declared as std_logic_vectors but you are trying to assign an integer to them.
Teacher drjohnsmith
can you post as an attatchment all your code and the test benche please, then we can advise
Scholar u4223374
@karahanli I could be wrong, but I think you're doing three separate divide operations here too. Vivado knows how to do a divide, but you'd better be prepared for a very large and slow piece of hardware - dividing by anything other than a power of 2 is not easy.
Visitor karahanli
Thanks for your help. but I still haven't solved the problem. I only use these libraries.
--Kütüphaneler
library IEEE;
--use ieee.numeric_std.all;
 --use ieee.std_logic_unsigned.all;
-- use ieee.std_logic_signed.all;
entity VGA_Test is
end VGA_Test;
component vga_pll
        --(Renk derinliği)
end component;
begin
    VGADriver : vga_pll
        generic map(1)
    process(X, Y)
    begin
        --Renk Paleti
        Gin(0) <= std_logic_vector(to_unsigned(X / 160, 3))(1);
        Rin(0) <= std_logic_vector(to_unsigned(X / 160, 3))(2);
    end process;
end Behavioral;
Scholar richardhead
Please report the errors you get now.
Visitor karahanli
Same errors.
Scholar richardhead
So the error is obvious, you cannot slice a type conversion. So you'll need to assign it to a temporary signal then slice that.
Teacher drjohnsmith
How are u expecting the hardware to implement X/160 ?
Draw out the logic your expecting would be informative.
I'd suggest, as u only want 3 bits out, that u construct either a 8 level case statement , or a constant look up table .
