Video Processing Subsystem
ERROR: [Synth 8-439] module 'bd_5c69_csc_0_v_csc' not found [d:/v_hdmi_rx_ss_0_ex -- VPSs/v_hdmi_rx_ss_0_ex.srcs/sources_1/bd/exdes/ip/exdes_v_proc_ss_0_0/bd_0/ip/ip_0/synth/bd_5c69_csc_0.v:185]
    Parameter C_S_AXI_CTRL_ADDR_WIDTH bound to: 32'sb00000000000000000000000000001000
    Parameter C_S_AXI_CTRL_DATA_WIDTH bound to: 32'sb00000000000000000000000000100000
ERROR: [Synth 8-6156] failed synthesizing module 'bd_5c69_csc_0' [d://v_hdmi_rx_ss_0_ex - VPSs/v_hdmi_rx_ss_0_ex.srcs/sources_1/bd/exdes/ip/exdes_v_proc_ss_0_0/bd_0/ip/ip_0/synth/bd_5c69_csc_0.v:57]
Windows 10
Vivado 2018.2
What is the reason for not synthesizable Video Sub System IP, that is integrated in the system design.
Prasanna Daram
Re: Video Processing Subsystem
Hi @daram123,
I believe I know what is the issue. In your initial project you have spaces characters. Vivado HLS will not like that at all.
In the packages project, the spaces are gone from the path thus you faced no issue. You should always avoid using spaces in your path, prefer underscores.
Best Regards,
@daram123
Try resetting BD output products and regenerate them again.
--Syed
All goes through except Video Processing SS IP.`
Prasanna Daram
@daram123
Try recustomizng the VSS IP and check. I suspect this to be an intermittent issue
Can you share the vivado project to debug the issue?
--Syed
Hi @daram123,
Are you trying to synthesize the BD in non-project mode?
Please check the link https://www.xilinx.com/support/answers/70400.html
Raj Singh.
It is in Project mode. I reset and generate it  is showing the same result.
Prasanna Daram
Project is not uploading.. is there a specific way to send you prj.
Prasanna Daram
@daram123
I have sent you a private message from ezmove. Please upload the archive project from ezmove and send it back to us.
--Syed
Yeah It will whiz you in aminute.
Prasanna Daram
Hi @daram123,
Few ideas:
  • Check the vivado_hls.log file under project.runs/...csc_synth_1. It should contain the error
  • If you do not have any error, try to use the TPG license
My guess is that your path is too long if you are using windows. This will be indicated by the vivado_hls.log
ViVADO_HLS.log is only found under TPG IP. I didnt notice the hls.log for Video Processing SubSystem_synth1.
Synthesis has not generated any files under /...csc_synth_1. I tried re generating products in a new project and still its same.
Prasanna Daram
Hi @daram123,
I had an error very similar to you and @florentw helped me to solve it as you can see here:
https://forums.xilinx.com/t5/Video/VPSS-2-0-doesn-t-syntetize/m-p/886118#M21624
My problem was that I enabled beta devices in init.tcl and beta devices are not supported by HLS.
I hope that this could help.
@pierlumi neither have
init.tcl
 Or have any vivado_init.tcl. in /...scripts
What i can do ?
@daram123
I do not have win10 so I have asked my colleague to run synthesis who has win10. I will get back to you on this.
On Linux OS, I reset and regenerated the output products using "OOC per BD". The OOC run and main top module synthesis run completed successfully without any error message.
Can you try the same on your machine?
--Syed
@daram123,
if you are not using init.tcl or vivado_init.tcl the problem seems not to be what I suggested you. Did you try shortening path for example C:/x as suggested by @florentw?
@pierlum Yes.
Now I have initialzed to run out of context per block design.
Prasanna Daram
Hi @daram123,
I was just checking the files received from @syedz and synthesis does not error out for this design in Win10 2018.2. The only thing done was regenerating the IPs with OOC per IP.
Prathik
Don't forget to reply, kudo, and mark the appropriate post as 'accept as solution'.
@syedz@prathikm
Out of context per block has these messages.
ERROR: [Synth 8-439] module 'bd_5c69_csc_0_v_csc' not found [d:/v_hdmi_rx_ss_0_ex - vpss/v_hdmi_rx_ss_0_ex.srcs/sources_1/bd/exdes/ip/exdes_v_proc_ss_0_0/bd_0/ip/ip_0/synth/bd_5c69_csc_0.v:185]
ERROR: [Synth 8-6156] failed synthesizing module 'bd_5c69_csc_0' [d:/v_hdmi_rx_ss_0_ex - vpss/v_hdmi_rx_ss_0_ex.srcs/sources_1/bd/exdes/ip/exdes_v_proc_ss_0_0/bd_0/ip/ip_0/synth/bd_5c69_csc_0.v:57]
ERROR: [Synth 8-6156] failed synthesizing module 'bd_5c69' [d:/v_hdmi_rx_ss_0_ex - vpss/v_hdmi_rx_ss_0_ex.srcs/sources_1/bd/exdes/ip/exdes_v_proc_ss_0_0/bd_0/synth/bd_5c69.v:10]
ERROR: [Synth 8-6156] failed synthesizing module 'exdes_v_proc_ss_0_0' [d:/v_hdmi_rx_ss_0_ex - vpss/v_hdmi_rx_ss_0_ex.srcs/sources_1/bd/exdes/ip/exdes_v_proc_ss_0_0/synth/exdes_v_proc_ss_0_0.v:58]
ERROR: [Synth 8-6156] failed synthesizing module 'exdes' [D:/v_hdmi_rx_ss_0_ex - vpss/v_hdmi_rx_ss_0_ex.srcs/sources_1/bd/exdes/synth/exdes.v:393]
Prasanna Daram
@daram123
Do you have the license of the IP which you are using?
Run "report_ip_status -file ip_status.rpt" command and share the generated ip_status.rpt file.
Also run the following command from Vivado TCL console to generate xinfo.txt
report_environment -file xinfo.txt
After running the command just type “pwd” this will show you the path where the xinfo.txt and ip_status.rpt file is generated. You can browse to that path and find the files.
--Syed
These are the files.
Prasanna Daram
@daram123
I have verified the xinfo and it looks you have valid purchase and HW eval license of the IP in the design.
Can you recreate the project at the different location (smaller dir path)and check? My colleague @prathikm has tested the design on Win10 os and it has synthesized successfully.
Also Try clearing the cache of the IP. Please check this thread:
https://forums.xilinx.com/t5/Installation-and-Licensing/Fail-to-generate-bitstream-with-Harware-evaluation-licence/m-p/892218#M23519
--Syed
Aila the archived project synthesized succesfuly.
got the bitstream. thank you
Prasanna Daram
Hi @daram123,
Best Regards,
@daram123
How did you solve this?
Vinay Shenoy
Hi @vinay_shenoy,
He replaced the space characters from his path to underscores
@vinay_shenoyI archived Project from file->Project->archive.
Prasanna Daram
Hi @daram123
Do you mean that you've just achieved the project and then recompiled it to solve this issue?
Vinay
Vinay Shenoy
