aherson
Vivado 2014.4 PROJECT_PARAM.PART
I am having a hard time with the Vivado 2014.4 migration.  I am stuck on four instances of:
[IP_Flow 19-2232] Current project options are not valid, cannot get 'PROJECT_PARAM.PART'
When I search with a text editor for "PROJECT_PARAM" in *.xci files, I get no hits.
Any suggestions?
(BTW I succesfully migrated from 2014.1 to 2014.3 just 3 weeks ago...)
(Project mode, KUS 040 in the 1156 package)
Thank You,
A
aherson
Quick update:  I had to regenerate all IP within the tool to get this to work.  Seems I am over the hill now.
Root cause is unfound...
A
vemulad
What is the exact part you are using?
Can you run report IP status from Tools --> report--> report IP status and attach the snapshot here?
Deepika.
Deepika.
aherson
Here is my IP status.  All are up to date and current to xcku040-ffva1156-2-e
All but 5 are Xilinx IP.  And, I am seeing 4 errors.  Could this be an OOC thing?
A
aherson
here is some more info from the logs.
A
aherson
and another note:
IP Settings -> Refresh All generates these errors every time.
(and also, recreating the BD from scratch does not solve the issue).
Thank You,
A
aherson
A
gyifan
I got the same issue. But I think I have found the cause.
In the Project Settings -> IP Repositories, please make sure you didn't include a project that sources other IPs. For example, if you have Project_A and IP_B in directory BASE. And Project_A uses IP_B and have copied B.xml to Project_A.src/. Then Vivado would have this issue if you set the Repositories to BASE. I think it is because Vivado sees two copy of B.xml and got confused.
Hope this would help someone.
Yifan
mvisser
Thanks, it did point me in the right direction.
In my case, the IP Repository folder had been booked into git and updating it from the server pulled in references to a part that did not exist in the version of Vivado that I am using. Deleting those locally resolved the issue.
