Observer jsduran4xilinx
Vivado 2016.3 keeps crashing with memory problems/stack dump
I have Vivado 2016.3 running on Ubuntu 16.04 LTS.
Vivado keeps crashing during elaboration.  Before it would not give any messages.  Then I started running as root.  I also added A LOT of swap space -- like over 128G.  My system has 1G RAM.
Can anybody please help?  I have to say that the fact that it is impossible to contact any actual Xilinx personnel is a bad mark for Xilinx so far -- not to mention the buggy software.
I run:
sudo /opt/Xilinx/Vivado/2016.3/bin/vivado -mode gui -jvm Xmx2048m
Then on the terminal I get:
start_gui
tcmalloc: large alloc 1073741824 bytes == 0x7f80b3264000 @ 0x7f8879c9b456 0x7f8879cbf399 0x7f88577cddc7
tcmalloc: large alloc 2147483648 bytes == 0x7f7ff3264000 @ 0x7f8879c9b456 0x7f8879cbf399 0x7f88577cddc7
tcmalloc: large alloc 2147483648 bytes == 0x7f7f73264000 @ 0x7f8879c9b456 0x7f8879cbf399 0x7f88577cddd6
tcmalloc: large alloc 4294967296 bytes == 0x7f7e73264000 @ 0x7f8879c9b456 0x7f8879cbf399 0x7f88577cddc7
tcmalloc: large alloc 4294967296 bytes == 0x7f7d72a64000 @ 0x7f8879c9b456 0x7f8879cbf399 0x7f88577cddd6
tcmalloc: large alloc 8589934592 bytes == 0x7f7b72a64000 @ 0x7f8879c9b456 0x7f8879cbf399 0x7f88577cddc7
tcmalloc: large alloc 8589934592 bytes == 0x7f7972264000 @ 0x7f8879c9b456 0x7f8879cbf399 0x7f88577cddd6
Abnormal program termination (11)
Please check '/home/saul/hs_err_pid10560.log' for details
In the given file there is:
# An unexpected error has occurred (11)
Stack:
/opt/Xilinx/Vivado/2016.3/tps/lnx64/jre/lib/amd64/server/libjvm.so(+0x91ab39) [0x7f8843fd4b39]
/opt/Xilinx/Vivado/2016.3/tps/lnx64/jre/lib/amd64/server/libjvm.so(JVM_handle_linux_signal+0xb6) [0x7f8843fdaf26]
/opt/Xilinx/Vivado/2016.3/tps/lnx64/jre/lib/amd64/server/libjvm.so(+0x917753) [0x7f8843fd1753]
/lib/x86_64-linux-gnu/libc.so.6(+0x354a0) [0x7f88784124a0]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_netlist.so(HDLHStrings::findID(char const*)+0x9d) [0x7f88577cdb3d]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_netlist.so(HDLHScalarNet::HDLHScalarNet(HDLHDbMgr*, HDLHCellview*, std::string const&, unsigned int)+0x2c) [0x7f88577cd05c]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_netlist.so(HANENetlistBuilder::createNet(HDLHCellview*, std::string const&, unsigned int)+0x3d) [0x7f8857835ded]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_synth.so(HANROasysTranslatorImpl::importPortNetInfo(NNet, HDLHCellview*, hanrPortInfo&)+0xce5) [0x7f8849f54d75]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_synth.so(HANROasysTranslatorImpl::importOneInstancePort(hanrPortInfo&, NInst&, HDLHCellview*, HDLHInstance*)+0x22a) [0x7f8849f5561a]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_synth.so(HANROasysTranslatorImpl::buildPortInfo(NInst&, HDLHCellview*, HDLHInstance*)+0x3c5) [0x7f8849f55c65]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_synth.so(HANROasysTranslatorImpl::importInstanceInfo(NInst, HDLHCellview*, HDLHCellview*, bool, HANROasysTranslatorImpl::CellCharacterization const&)+0x1bd) [0x7f8849f5621d]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_synth.so(HANROasysTranslatorImpl::translateSubtreeR(NRef, NInst)+0x54f) [0x7f8849f583ef]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_synth.so(HANROasysTranslatorImpl::translateSubtreeR(NRef, NInst)+0x4e7) [0x7f8849f58387]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_synth.so(HANROasysTranslatorImpl::populate_(HANENetlist*, HDGUIStatus&)+0x747) [0x7f8849f5add7]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_synth.so(HANROasysTranslatorImpl::populate(HANENetlist*, HDGUIStatus&)+0x91) [0x7f8849f5b711]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_netlist.so(HANENetlistCreator::execute(HDARPart const*, HDGUIStatus&)+0x77) [0x7f885783d2a7]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_project.so(HAPRProjUtils::openRodinElabNetlist(HAPRProject*, HAPRDesignSpec const&, HDARPart const*, HDGUIStatus&)+0x692) [0x7f8854317a02]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_project.so(HAPRDesign::openNetlist_(HDGUIStatus&)+0x26d) [0x7f88542b104d]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_project.so(HAPRDesign::openAndProcessNetlist_(HDGUIStatus&, bool, bool&)+0x177) [0x7f88542b47b7]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_project.so(HAPRDesign::refreshDesign(HDGUIStatus&, bool)+0x240) [0x7f88542b56f0]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_project.so(HAPRProject::openDesign_(HAPRDesignSpec const&, HDGUIStatus&, bool)+0x75) [0x7f8854342e35]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_project.so(HAPRProject::elaborate(HDARPart const*, HADAFileSet*, HADAFileSet*, std::string const&, bool, std::string const&, bool, bool, int, bool, bool, bool, bool, HDGUIStatus&)+0x14a) [0x7f885434340a]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_vivadotasks.so(+0x3c3ae4) [0x7f8846f72ae4]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_vivadotasks.so(+0x3cc5ef) [0x7f8846f7b5ef]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_common.so(+0x5f8f57) [0x7f88794c1f57]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/libtcl8.5.so(+0x331f5) [0x7f88743bf1f5]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/libtcl8.5.so(+0x76bbe) [0x7f8874402bbe]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/libtcl8.5.so(+0x7e767) [0x7f887440a767]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/libtcl8.5.so(TclEvalObjEx+0x77) [0x7f88743c1327]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_common.so(+0x5f866c) [0x7f88794c166c]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/libtcl8.5.so(Tcl_ServiceEvent+0x87) [0x7f8874433b37]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/libtcl8.5.so(Tcl_DoOneEvent+0x129) [0x7f8874433e69]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_commontasks.so(+0x304aa5) [0x7f88703e1aa5]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_commontasks.so(+0x30c28b) [0x7f88703e928b]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_commontasks.so(+0x304d43) [0x7f88703e1d43]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/libtcl8.5.so(Tcl_EvalObjv+0x32) [0x7f88743bf7e2]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/libtcl8.5.so(TclEvalObjEx+0x322) [0x7f88743c15d2]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_commonmain.so(+0x6430) [0x7f8878cc4430]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/libtcl8.5.so(Tcl_Main+0x1d5) [0x7f887442c175]
/opt/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_common.so(+0x631d29) [0x7f88794fad29]
/lib/x86_64-linux-gnu/libpthread.so.0(+0x76aa) [0x7f8877ebe6aa]
/lib/x86_64-linux-gnu/libc.so.6(clone+0x6d) [0x7f88784e3b5d]
It is getting to be absurd how hard it is to get Vivado running.  I mean, it is not as if it is freeware!
Re: Vivado 2016.3 keeps crashing with memory problems/stack dump
Hi @jsduran4xilinx
Would you be able to share the test design to debug this issue?
Voyager
Voyager
Review the installation guide, you'll need more than 1G of RAM.  Typical installs are 8G RAM minimum (I'm using 16G).
https://www.xilinx.com/design-tools/vivado/memory.htm
check these links
https://forums.xilinx.com/t5/Embedded-Development-Tools/No-connection-to-program-Zedboard-Vivado-2016-3-Ubuntu-16-04/td-p/729059
https://forums.xilinx.com/t5/Simulation-and-Verification/Vivado-2016-3-crashing/m-p/733770#M17266
https://www.xilinx.com/support/answers/67580.html
https://www.xilinx.com/support/documentation-navigation/design-hubs/dh0013-vivado-installation-and-licensing-hub.html
Thanks and Regards
Balkrishan
That was an unfortunate typo.  I have 16GB of RAM.
Unfortunately, I cannot.
This is probably a silly question, but just to cover the bases -- do you personally know people successfully using Vivado 2016.3 on Ubuntu 14.04?
Hi @jsduran4xilinx,
Ubuntu 14.04 is not supported for Vivado 2016.3. Please go through page-15 of https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_3/ug973-vivado-release-notes-install-license.pdf for list of supported OS.
Can you try with 2015.2 as it's supported for 14.04. Please go through page-9 of https://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_2/ug973-vivado-release-notes-install-license.pdf
Arpan
Arpan,
Thanks, but I am using Ubuntu 16.04.
Hi @jsduran4xilinx,
But in the previous post you mentioned " do you personally know people successfully using Vivado 2016.3 on Ubuntu 14.04", that's why I got confused. Can you please attach the output xinfo.txt of below tcl command:
report_environment -file xinfo.txt
Arpan
Yeah.  Sorry about that, another typo.  I am using 16.04.
At this point I have switched to a bottom-up methodology, since modules of my design do seem to be going through ok.
At least from my experience here, and from various posts on the message boards, it would seem that Vivado does have some sort of memory problem with design of moderate size on Ubuntu 16.04.  I admit it is still possible that this is "operator error", but perhaps something for you guys at Xilinx to keep an eye on.
Thanks!
I had the same problem with older vivado versions (<2016.3) with ubuntu 16.04. Same design with ubuntu 14.04 works.
I hoped the issue was solved with 2016.3, but it doesn't look like. The issue is still there.
My system is a i7-6700 with 8 cores and 16GB memory.
$ cat hs_err_pid8064.log
Stack:
/lib/x86_64-linux-gnu/libc.so.6(+0x354a0) [0x7f23634744a0]
/lib/x86_64-linux-gnu/libpthread.so.0(+0x12960) [0x7f2362f2b960]
/home/michael/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_synth.so(HARTNDb::waitForLoadPart()+0x49) [0x7f2334a7fd89]
/home/michael/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_synth.so(+0xc7252f) [0x7f2334c2052f]
/home/michael/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_synth.so(+0xb4ab85) [0x7f2334af8b85]
/home/michael/Xilinx/Vivado/2016.3/lib/lnx64.o/libtcl8.5.so(+0x331f5) [0x7f235f4211f5]
/home/michael/Xilinx/Vivado/2016.3/lib/lnx64.o/libtcl8.5.so(+0x76bbe) [0x7f235f464bbe]
/home/michael/Xilinx/Vivado/2016.3/lib/lnx64.o/libtcl8.5.so(+0x7e767) [0x7f235f46c767]
/home/michael/Xilinx/Vivado/2016.3/lib/lnx64.o/libtcl8.5.so(TclEvalObjEx+0x77) [0x7f235f423327]
/home/michael/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_commontasks.so(+0x2d0887) [0x7f235ad28887]
/home/michael/Xilinx/Vivado/2016.3/lib/lnx64.o/libtcl8.5.so(Tcl_ExprObj+0xfb) [0x7f235f46c33b]
/home/michael/Xilinx/Vivado/2016.3/lib/lnx64.o/libtcl8.5.so(Tcl_ExprBooleanObj+0x16) [0x7f235f4220c6]
/home/michael/Xilinx/Vivado/2016.3/lib/lnx64.o/libtcl8.5.so(+0x3eae8) [0x7f235f42cae8]
/home/michael/Xilinx/Vivado/2016.3/lib/lnx64.o/libtcl8.5.so(+0x34d6b) [0x7f235f422d6b]
/home/michael/Xilinx/Vivado/2016.3/lib/lnx64.o/libtcl8.5.so(Tcl_EvalEx+0x16) [0x7f235f423276]
/home/michael/Xilinx/Vivado/2016.3/lib/lnx64.o/libtcl8.5.so(Tcl_FSEvalFileEx+0x1d2) [0x7f235f487d02]
/home/michael/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_commontasks.so(+0x2edfb2) [0x7f235ad45fb2]
/home/michael/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_common.so(+0x5f8f57) [0x7f2364523f57]
/home/michael/Xilinx/Vivado/2016.3/lib/lnx64.o/libtcl8.5.so(+0xb740f) [0x7f235f4a540f]
/home/michael/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_commontasks.so(+0x2d0924) [0x7f235ad28924]
/home/michael/Xilinx/Vivado/2016.3/lib/lnx64.o/libtcl8.5.so(+0xad531) [0x7f235f49b531]
/home/michael/Xilinx/Vivado/2016.3/lib/lnx64.o/libtcl8.5.so(+0x3491c) [0x7f235f42291c]
/home/michael/Xilinx/Vivado/2016.3/lib/lnx64.o/libtcl8.5.so(Tcl_EvalObjv+0x32) [0x7f235f4217e2]
/home/michael/Xilinx/Vivado/2016.3/lib/lnx64.o/libtcl8.5.so(TclEvalObjEx+0x322) [0x7f235f4235d2]
/home/michael/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_common.so(hdi::tcltasks::task_manager::eval_in_tcl(Tcl_Interp*, Tcl_Obj*, char const*, bool)+0x7fd) [0x7f236452591d]
/home/michael/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_designutils.so(HRTInvoker::inProcessLaunch(HDGUIStatus&)+0x1ef) [0x7f234fb3b7df]
/home/michael/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_designutils.so(HRTInvoker::launch(HDGUIStatus&)+0x4b5) [0x7f234fb3c535]
/home/michael/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_vivadotasks.so(+0x3c4e77) [0x7f23318eee77]
/home/michael/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_vivadotasks.so(+0x3cc5ef) [0x7f23318f65ef]
/home/michael/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_commontasks.so(+0x30bef9) [0x7f235ad63ef9]
/home/michael/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_commontasks.so(+0x304d43) [0x7f235ad5cd43]
/home/michael/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_commonmain.so(+0x6430) [0x7f2363d26430]
/home/michael/Xilinx/Vivado/2016.3/lib/lnx64.o/libtcl8.5.so(Tcl_Main+0x1d5) [0x7f235f48e175]
/home/michael/Xilinx/Vivado/2016.3/lib/lnx64.o/librdi_common.so(+0x631d29) [0x7f236455cd29]
/lib/x86_64-linux-gnu/libpthread.so.0(+0x76fa) [0x7f2362f206fa]
/lib/x86_64-linux-gnu/libc.so.6(clone+0x6d) [0x7f2363545b5d]
