Vivado 2018.1 Synthesis - [Synth 8-2947] errors when using VHDL-2008 in Windows
When using VHDL-2008 source files in Vivado 2018.1 on a Windows machine, users may get the following errors during Synthesis, or when using "Open Elaborated Design":
Starting RTL Elaboration : Time (s): cpu = 00:00:05 ; elapsed = 00:00:05 . Memory (MB): peak = 420.273 ; gain = 111.703
ERROR: [Synth 8-2947] error reading binary file 'C:/Xilinx/Vivado/2018.1/scripts/rt/data/vhdl/pkgs/2008/vdbs/ieee/std_logic_1164.vdb'
ERROR: [Synth 8-1086] ieee.std_logic_1164 failed to restore
ERROR: [Synth 8-4169] error in use clause: package 'std_logic_1164' not found in library 'ieee' [C:/Xilinx/Vivado/2018.1/scripts/rt/data/unisim_VCOMP.vhd:11]
ERROR: [Synth 8-2947] error reading binary file 'C:/Xilinx/Vivado/2018.1/scripts/rt/data/vhdl/pkgs/2008/vdbs/ieee/numeric_std.vdb'
ERROR: [Synth 8-1086] ieee.numeric_std failed to restore
ERROR: [Synth 8-4169] error in use clause: package 'numeric_std' not found in library 'ieee' [C:/Xilinx/Vivado/2018.1/scripts/rt/data/unisim_VCOMP.vhd:12]
ERROR: [Synth 8-2947] error reading binary file 'C:/Xilinx/Vivado/2018.1/scripts/rt/data/vhdl/pkgs/2008/vdbs/std/standard.vdb'
ERROR: [Synth 8-1086] std.standard failed to restore
ERROR: [Synth 8-4169] error in use clause: package 'standard' not found in library 'std' [C:/Xilinx/Vivado/2018.1/scripts/rt/data/unisim_VCOMP.vhd:13]
ERROR: [Synth 8-1031] string is not declared [C:/Xilinx/Vivado/2018.1/scripts/rt/data/unisim_VCOMP.vhd:14]
ERROR: [Synth 8-1031] std_ulogic is not declared [C:/Xilinx/Vivado/2018.1/scripts/rt/data/unisim_VCOMP.vhd:68]
ERROR: [Synth 8-1031] std_ulogic is not declared [C:/Xilinx/Vivado/2018.1/scripts/rt/data/unisim_VCOMP.vhd:69]
ERROR: [Synth 8-1031] std_ulogic is not declared [C:/Xilinx/Vivado/2018.1/scripts/rt/data/unisim_VCOMP.vhd:70]
ERROR: [Synth 8-2398] near string "PRIMITIVE" ; 0 visible types match here [C:/Xilinx/Vivado/2018.1/scripts/rt/data/unisim_VCOMP.vhd:74]
ERROR: [Synth 8-1031] std_ulogic is not declared [C:/Xilinx/Vivado/2018.1/scripts/rt/data/unisim_VCOMP.vhd:79]
ERROR: [Synth 8-1031] std_ulogic is not declared [C:/Xilinx/Vivado/2018.1/scripts/rt/data/unisim_VCOMP.vhd:80]
ERROR: [Synth 8-1031] std_ulogic is not declared [C:/Xilinx/Vivado/2018.1/scripts/rt/data/unisim_VCOMP.vhd:81]
ERROR: [Synth 8-2398] near string "PRIMITIVE" ; 0 visible types match here [C:/Xilinx/Vivado/2018.1/scripts/rt/data/unisim_VCOMP.vhd:85]
ERROR: [Synth 8-1031] bit is not declared [C:/Xilinx/Vivado/2018.1/scripts/rt/data/unisim_VCOMP.vhd:90]
This issue is not present for Linux users.
For Windows users, please use the below Answer Record and apply the patch to resolve this issue.
https://www.xilinx.com/support/answers/70908.html
Please don’t forget to reply, kudo, and accept as solution!
