Vivado 2018.2 Synthesis bug with record containing null array
Vivado 2018.2 synthesis crashes if a record containing a null array is marked as debug.
Minimal example:
library ieee;
use ieee.std_logic_1164.all;
package top_pkg is
    type foo is record
        bar : std_logic_vector(-1 downto 0);
    end record;
end package;
library ieee;
use work.top_pkg.all;
entity top is
    port ( i : in foo );
end top;
architecture rtl of top is
    attribute mark_debug : string;
    attribute mark_debug of i : signal is "true";
begin
end rtl;
This crashes with
Abnormal program termination (EXCEPTION_ACCESS_VIOLATION)
Re: Vivado 2018.2 Synthesis bug with record containing null array
Hi @josh_tyler, thanks for reporting this crash. I was able to reproduce it and have reported it to development to fix in a future release.
Please don’t forget to reply, kudo, and accept as solution!
Scholar brimdavis
@josh_tyler   "Vivado 2018.2 synthesis crashes if a record containing a null array is marked as debug."
Important note: Vivado does *NOT* correctly synthesize records containing null elements - it just deletes the entire record.
  https://www.xilinx.com/support/answers/66920.html
  https://forums.xilinx.com/t5/Synthesis/VHDL-Bug-Report-Vivado-Removes-non-null-port/m-p/850764#M25827
-Brian
Scholar richardhead
@kmorris
Will the null record removal bug also be fixed?
@brimdavis Thank you for the heads up, that's quite shocking behavior!
Hi @richardhead, I don't have an ETA, but this support is still in process to be added in Vivado.
