ross@bitbybitsp.com
Vivado 2019.2 recursion bug: ERROR: [Synth 8-316] illegal module recursion detected
Is this the right place to post about Vivado Synthesis bugs?
I've found that Vivado has a bug handling recursive code.  I've simplified it down to a simple test case, where some code sythesizes and identical code throws a synthesis error.  I say "identical" code because all the statements are exactly the same.  They're just given in a different order.  Apparently when Vivado 2019.2 handles recursion it matters what *order* System Verilog statements are given in.
This code synthesizes without errors in Vivado 2019.2:
`timescale 1ps / 1ps
`define w assign
module recursion_test_1
parameter LEVEL = 2
output [31:0] y
generate
if(LEVEL==0)
begin
`w y = 0;
end
else
begin
wire [31:0] y_inner;
recursion_test_1 #(.LEVEL(LEVEL-1)) inner_rec_1 (.y(y_inner));
`w y = y_inner + 1;
end
if(LEVEL==2)
begin
initial $display("y at LEVEL %d is %d", LEVEL, y);
end
endgenerate
endmodule // recursion_test_1
This code does not synthesize in Vivado 2019.2 with an "illegal module recursion detected" error:
`define w assign
module recursion_test_2
parameter LEVEL = 2
output [31:0] y
generate
if(LEVEL==2)
begin
end
if(LEVEL==0)
begin
`w y = 0;
end
else
begin
recursion_test_2 #(.LEVEL(LEVEL-1)) inner_rec_2 (.y(y_inner));
`w y = y_inner + 1;
end
endgenerate
endmodule // recursion_test_2
What's different about the two pieces of code is whether the "if(LEVEL==2)" block of code is before or after the "if(LEVEL==0)" block.  My best guess is that Vivado requires recursion to occur in the first conditional block in the first generate statement, or else it throws an indecipherable error.
It would be nice if this is fixed, or at least if the error message is changed to say it's a Vivado limitation rather than an error in the Verilog code, with perhaps a pointer to the correct documentation that describes how to implement recursion in a way that Vivado supports.
pulim
Hi ross@bitbybitsp.com
Thanks for reporting this issue. I am looking into this. will update you.
Manusha
pulim
I filed a CR to get this issue fixed in upcoming releases.
Manusha
