Visitor dvdgardner
Vivado Support for SystemVerilog "Access to interface objects"
Section 25.10 of the systemverilog LRM, Access to interface objects, shows that we can have a typedef on an interface object, and that the typdef can be referenced with dot notation.
This works with Vivado but only if I restrict the design to referencing the typdef once, in a single instance.  If fails if I have a second instance.
This seems like a Vivado bug.  Am I missing anything?  If not, how do we go about getting this fixed?
The code below illustrates the problem.  Here are the key observations:
Note 1: This file will compile successfully if you comment out either of the passthrough instances, but fails when you have two instances.
Note 2: If both passthrough instances are included then Vivado 2017.4 & 2018.1 report the following error:
 [Synth 8-448] named port connection 'food_in\.food[bananahs]' does not exist for instance 'bananahs_passthrough' of module 'N_150D62B0' ["/home/dgardner/workspace/fpga/experiment/project_1/project_1.srcs/sources_1/new/top.sv":50]
Note 3: This code compiles and simulates in Modelsim 10.3d
Note 4: This code compiles and synthesizes in Quartus 16.1
`timescale 1ns / 1ps
typedef struct packed {
    logic [31:0] kernels;
} popcorn_t;
    logic [15:0] bananahs;
} bananahs_t;
interface bananahs_if ();
   typedef bananahs_t food_t;
   food_t food;
endinterface
interface popcorn_if ();
   typedef popcorn_t food_t;
   food_t food;
endinterface
module passthrough
      interface food_in,
      interface food_out
    food_in.food_t food;
    assign food = food_in.food;
    assign food_out.food = food;
endmodule
module top
      popcorn_if popcorn_in,
      popcorn_if popcorn_out,
      bananahs_if bananahs_in,
      bananahs_if bananahs_out
    passthrough popcorn_passthrough (
      .food_in(popcorn_in),
      .food_out(popcorn_out)
    passthrough bananahs_passthrough (
      .food_in(bananahs_in),  // <-- Ref Note 2.  This is the line vivado points to in the error message (line 50).
      .food_out(bananahs_out)
endmodule
Re: Vivado Support for SystemVerilog "Access to interface objects"
I was able to take the sample RTL you provided and got the same results. The module referenced doesn't exist in the RTL, so user's would not be able to debug it. It is also odd that using only one instantiation of the module works, but not any more. I have filed a CR with development to analyze this further, and to see if there are ways to get around this error.
Please don’t forget to reply, kudo, and accept as solution!
Visitor dvdgardner
Thanks for that.
How can track the status of this?  It's currently blocking some library design work.
-David
Hi David, in order to track this, you need to create an SR via the service portal, or contact your local FAE to create an SR.
The issue appears to be due to the generic 'interface' passthrough as module ports. If these are changed to specific interfaces, the error does not occur. However, if you are trying to use different widths for elements of the interface, it may be better to use parameterized interfaces as a potential workaround.
Visitor dvdgardner
This is crazy.  I've been trying for two weeks but Xilinx refuses to provide support to me.  Perhaps someone else can open an SR on my behalf while I try to work through the support issue?  All of the details necessary are in the original post.
Historian
Historian
To be clear - @kmorris has already submitted a CR (change request) - so everything required to get the bug fixed has already been done.
The SR will only allow you to get an update on the status of the CR, which (assuming development agrees) will be fixed "at some point in the future". So you don't need to do anything else - the bug is already in the system. Maybe @kmorris can get you a status update...
Avrum
Visitor dvdgardner
I ran into another variation of this issue which is simpler that the previous sample code I posted.  Turns out the issue can occur even without accessing the typedef on the interface.
   bit foo;
endinterface
   bit bar;
endinterface
module passthrough
      interface food_in,
      interface food_out
    assign food_in = food_out;
endmodule
module top
endmodule
@kmorris, can you provide an update on the existing CR?
Scholar markcurry
Interfaces cannot be assigned like a wire.  This isn't a Vivado issue, but a SystemVerilog language issue.  The spec doesn't even go into details as to what would be "type" compatible between different interfaces
The need is there to do what you're asking.  However, the language is lacking int this.  We've not found a reusable way of doing this, rather only interface specific.  I can go into more details if you like, but the method you're tackling it isn't how the language is designed.
Mark
@dvdgardner, the CR has been fixed for the Vivado 2018.3 release. Using the original RTL no longer produces an error in this version.
Scholar markcurry
FYI - the suggestions I would make to the SystemVerilog Working group (anyone know if it still even exists?) would be to expand the "net alias" (Section 10.11) to also work with interfaces:
module passthrough
      interface food_in,
      interface food_out
    alias food_in = food_out;
endmodule
Interfaces would need to be explicitly equivalent (i.e. exact same definition) for this to work, or an error would be indicated.
Where we really need this is when using ARRAYs of interfaces, and want to call out an individual index by name:
some_if some_if_array()[ N - 1 : 0 ];
some_if one_specific_if();
some_if another_specific_if();
alias one_specific_if = some_if_array[ 3 ];
localparam MY_INDEX = 2;
alias another_specific_if = some_if_array[ MY_INDEX ];
Mark
Visitor dvdgardner
@kmorris  Thanks for the update.  Was hoping to see a fix in 18.2 but 18.3 is the next best thing :-)
@markcurry Yes, I realize I simplified that second scenario a bit too far.  Though it is interesting to note that it sill generated the same form of error as the original case.
Here's an updated version (Still not using the typedef on the interface)
   struct packed  {
      logic  foo;
   } payload;
endinterface
   struct packed  {
      logic  bar;
   } payload;
endinterface
module passthrough
      interface food_in,
      interface food_out
    assign food_out.payload = food_in.payload;
endmodule
module top
endmodule
Scholar markcurry
Ah - that should work fine - even with Vivado 2018.1 I believe.  It doesn't?  I'll try your example on my end, and a few others (is it the structure within the interface that's the problem?).
We're doing similar things in Vivado, and it's working.  The only difference I can see is we're using Modports on the module ports, instead of the raw interface.
Mark
Scholar markcurry
Ok, I ran some tests.  This looks to be because of the attempt to make a generic interface feedthru, and Vivado doesn't like it.  If you create a interface specific feedthru, (with the EXACT same contents) it works.
I'm suspecting Vivado just doesn't handle generic interfaces on the portlists.  We use interfaces a lot, but dont use generic interfaces on portlists.  In fact we always use specifc modports, not specific interfaces on portlists.
It appears that Vivado, on the first instance of a "generic" interface on a port - is contextualizing the module port to that exact interface.  Even though "bananahs_if", and "popcorn_if" has an identical member "payload", Vivado is barfing.
Below works:
   struct packed  {
      logic  foo;
   } payload;
endinterface
   struct packed  {
      logic  bar;
   } payload;
endinterface
module passthrough_popcorn
      interface food_in,
      interface food_out
endmodule
module passthrough_banana
      interface food_in,
      interface food_out
endmodule
module if_test60
    passthrough_popcorn popcorn_passthrough (
    passthrough_banana bananahs_passthrough (
endmodule
As I mentioned in a previous post I believe this could all be solved in a different manner - with the "net alias" construct allowed to be used on interfaces.  But seeing as that requires a change in an LRM, then support by the tools - the likelihood of seeing this anytime soon is small.
Mark
