Visitor george_fornt
Vivado active netlists limit
Hello everybody,
Whenever I try to Synthesize my design I get the following error:
[Common 17-70] Application Exception: Number of active netlists exceeds limit (255)
I looked everywhere I could, but I didn't find any information about what does this limit mean, and how to avoid this error.
Is this "active netlists limit" just a limitation of the software, or is it related to the capacity of the FPGA I'm using? Is there any way to avoid it, or do I have to redo my design in order to reduce the number of netlists?
Thanks in advance for the help,
Jordi
Re: Vivado active netlists limit
Which Vivado version are you using?
Are you using a lot netlists (EDIF/NGC) in your design?
In which process did you receive this error? Looks like the error did not happen in Synthesis but at the beginning of Implementation, correct?
Can you post a screenshot of the Vivado GUI when this error occurs?
Vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
Vivian
Problem solved!
I was using Vivado 2016.4, WebPACK version. Then I installed Vivado 2017.1 and applied the License for the Desing Editions version, and the problem just vanished, without modifying anything on the design.
Jordi
