Observer nikhenri
Vivado bug with back-to-back VHDL attribute, report false error "ERROR [Synth 8-5882] found unsupported attribute"
Hi !
Is there a way to make make a back-to-back VHDL attribute work ?
The synthesis return a false error that the attribute is not supported, but the attribut is supported, it's seem having back-to-back attribute on Vivado cause an issue.
Exemple#1:
    signal clk_cnt      : integer range 100 downto 0 := 0;
    signal clk_cnt2     : clk_cnt'subtype; --The attribute IS supported
    clk_cnt        <= clk_cnt + 1 when(clk_cnt /= clk_cnt'subtype'high); --expect '100' got [Synth 8-5882] found unsupported attribute
Exemple #2:
type t_array_slv        is array (natural range <>) of std_logic_vector;
signal adc_data_ch      : t_array_slv(1 downto 0)(2 downto 0);
signal adc_data_ch2 : adc_data_ch'element; --the attribute IS supported
... adc_data_ch <= std_logic_vector(to_unsigned(adc_data, adc_data_ch'element'length)); --expect '3' got [Synth 8-5882] ... ...
It work well on Modelsim.
I tested and see the issue on the following version : 2016.4 & 2017.3
Re: Vivado bug with back-to-back VHDL attribute, report false error "ERROR [Synth 8-5882] found unsupported attribute"
Hi @nikhenri ,
I have created small testcase and checked with latest internal build and it still throws the same error for back to back VHDL attribute. Hence, the CR has been filed on it. Let developers look into it may make necessary changes in upcoming Vivado versions.
hemangd
@nikhenri
I doubt this is supported in Vivado, let me check and get back.
Anusheel
Scholar richardhead
'subtype has been confirmed as supported by xilinx
https://forums.xilinx.com/t5/Synthesis/VHDL-2008-Enhancement-request-subtype-attribute/m-p/839896
And given that 'element works, then chained attributes must work or there is a VHDL compile bug.
Hi @nikhenri ,
hemangd
Observer nikhenri
Thank you
Hi @nikhenri ,
Since the CR has been filed on this issue, please close the thread by marking it as accepted solution.
hemangd
