Visitor bodox
Vivado exported VHDL netlist port problem
Dear all,
Exported VHDL netlist swaps direction of ports vs RTL source - leading to a (simulation) bug
Thank you,
Bodo
Re: Vivado exported VHDL netlist port problem
Can you provide more details?
Which Vivado version are you using?
What command were you using to export the VHDL netlist, write_vhdl?
What is the port like in your original code and what is it like in the exported netlist file?
What's more, one thing you can do now for investigation is to check the direction of the port in the post-synth netlist (open synthesized design and check the schematic of the port).
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
Visitor bodox
2018.2
The problem shows during simulation with Cadence Incisive, not with Mentor Questasim. And it is going wrong during the elaboration.
Module from Xilinx in the schematic: axi_emc, port MEM_CEN is not in the schematic as it is the start-up interface of the Xilinx module.
Module in VHDL: axi_emc_v3_0_17, from Xilinx, line 284 for port mem_cen, (0 to 1), for component “axi_emc”, with “C_USE_STARTUP = 1” and “C_NUM_BANKS_MEM = 1”.
Module in VHDL: axi_emc_v3_0_vh_rfs.vhd, line 3646 for port mem_cen, ((C_NUM_BANKS_MEM-1) downto C_USE_STARTUP), so leading to (0 to 1) connected to (0 downto 1), as both constants have been defined above.
The schemaqtic after synthesis does not contain the MEM_CEN bus.
