Vivado synthesis cannot infer block RAM when two dual-port RAM read data are concatenated.
See attached.
If I explicitly tell it to use block ram with ram_style set as "block" I get the warning:
"WARNING: [Synth 8-3463] Infeasible ramstyle = block set for RAM RAM_A_reg,trying to implement using LUTRAM"
The fix, as shown in the attached file, is to put the two ram read statements in different processes.
Note that this issue is not seen with other synthesis tools.
Andrew
Re: Vivado synthesis cannot infer block RAM when two dual-port RAM read data are concatenated.
Hi Boots,
I understand your frustration, however officially we only supported what was shown in the XST templates.
I will start an internal discussion and see what are official statement is and if we plan to make any enhancements.
Best regards
Dries
Give Kudos to a post which you think is helpful and reply oriented by clicking the star next to the post.
Hi Andrew,
unfortunately, we only support and test for the memory templates that are supplied with Vivado (see the templates window)
We don't have a concatenated memory template.
However, I think it is possible to do what you want to do.
Basically, you need to cut the memories and put them into separate modules.
In the wrapper of these 2 memories, you can concatenate the outputs.
Side-note: you don't use the output pipeline register. The performance of your memories could be a limiting factor in the performance of your design.
Dries
I was hoping this would generate a change request. Shouldn't Vivado synthesis support the same RAM inferrence as other tools, including ISE? Shouldn't the RAM inferrence be made more robust?
I would like to point out that RAM inferrence issues cause a big headache when migrating to Vivado. It forces the Xilinx 7 series customer to go over every block ram in the design to ensure that Vivado has implemented it correctly and if not, to modify what could be library code. Code which is likely already in use in existing products and will have to be retested. This generates a level of uncertainty.
Andrew
Hi Boots,
Best regards
Dries
Hi Boots,
I got a positive response and approval to file a CR.
No commitment on when it will be fixed, but in general we do indeed claim compatibility with XST, so thank you for reporting this!
Also thanks for supplying a testcase! This helped to reproduce the issue and made it easier to file the CR.
Many thanks!
Dries
No problem. Thanks for the feedback! :)
Andrew
Hi Dries,
I want to inform you about onotherone problem with BLOCK RAM implementation.
Vivado synthesis cannot infer block RAM when Single-Port Block RAM is defined inside GENERATE block like in next example. ISE handle it correctly.
type t_hil_lut_mem is array (0 to (2 ** (HIL_LUT_ADDR_WIDTH+1))-1) of std_logic_vector(HIL_DATA_WIDTH-1 downto 0);
type t_hil_lut_mem_array is array (0 to HIL_LUT_NO_OF_UNITS-1) of t_hil_lut_mem;
signal lut_mem                 : t_hil_lut_mem_array := LUT_INIT_ARRAY;
GEN_LUTS: for i in 0 to NO_OF_LUTS-1 generate
  LUT_MEM_PROC : process (i_clk) begin
  if (rising_edge(i_clk)) then
    if (cb_mem_we(i) = '1') then
      lut_mem(i)(to_integer(unsigned(cb_addr(i)))) <= i_cb_wr_data(DATA_WIDTH-1 downto 0);
    end if;
  lut_mem_data(i) <= lut_mem(i)(to_integer(unsigned(lut_addr))); -- int read
  end if;
  end process;
  cb_addr(i) <= unsigned(not(field_select(i)) & cb_mem_addr);
end generate;
Three years have passed... Such funny limitations still exist :(
