tishi
Why vivado 2018 infers a*b+c as two DSP48E1
Hi, all
I recently switched tools from vivado 2016 to 2018, my project  failed with timing, all path with DSP48E1 failed with timing.
I start to dig out the difference, I found one thing,
The below test code synthesized as 1 dsp48e1 in vivado 2016, but 2 in vivado 2018.
module multacc(
clk ,
rst ,
en ,
a ,
b ,
c,
subadd ,
p
//ALUMODE = subadd
//OPMODE = 0100101
//preg=1
//rst->RSTP en->CEP
parameter a_bits = 6'd16;
parameter b_bits = 6'd8;
parameter c_bits = 6'd26;
parameter p_bits = 6'd26;
input clk ;
input rst ;
input en ;
input a ;
input b ;
input c;
input subadd ;
(* use_dsp48 = "yes" *)
output p ;
wire clk;
wire rst;
wire en;
wire signed [a_bits-1:0] a ;
wire signed [b_bits-1:0] b ;
wire signed [c_bits-1:0] c ;
wire subadd ;
reg signed [p_bits-1:0] p ;
reg signed [a_bits-1:0] a_r ;
reg signed [b_bits-1:0] b_r ;
reg signed [c_bits-1:0] c_r ;
reg subadd_r ;
always @(posedge clk)
begin
a_r <= a;
b_r <= b;
c_r <= c;
subadd_r <= subadd;
end
//if (rst) begin
// p <= 0;
//end else if (en) begin
if (subadd)
p <= c-a*b;
else
p <= a*b+c;
//end
endmodule
module substractor
input wire clk,
input wire rst,
input wire [15:0] a ,
input wire signed [7:0] b ,
input wire signed [25:0] c,
input wire subadd,
output reg [25:0] d
reg [15:0] a_r;
reg [7:0] b_r;
reg [25:0] c_r;
reg subadd_r;
wire [25:0] d_w;
begin
a_r <= a;
b_r <= b;
c_r <= c;
d <= d_w;
end
multacc multacc_inst(
.clk(clk) ,
.rst(rst) ,
.en(1) ,
.a(a_r) ,
.b(b_r) ,
.c(c_r),
.subadd(subadd_r) ,
.p(d_w)
endmodule
florentw
HI @tishi
Are you upgrading the project or creating a new project in 2018.x?
Can you make sure the synthesis settings are the same in both projects?
Florent
tishi
For unknown reason, actually the synthesized result is wrong, you can see from the schematic, subadd is unconnected, the following is not supported by one DSP.
if (subadd)
    p <= c-a*b;
else
    p <= a*b+c;
but below can,
if (subadd)
    p <= a*b-c;
else
    p <= a*b+c;
tishi
Correct my previous reply,
the synthesized result of vivado 2016 is wrong.
florentw
HI @tishi
Ok then it just means that the issue was fixed in the later version
Florent
benmen
you should have 2 stages of pipelining on the input of DSP48, adding one more pipeline stage would probably help in your case. Internally the DSP48 does the multiplication after 2 stages and the addition in the 3rd stage. So it would make sense to buffer your add operand 3 times, and then add this to the result of the multiplication. Something like this
//stage 1
a_d <= a;
b_d <= b;
c_d <= c;
//stage 2
a_dd < =a_d;
b_dd <= b_d;
c_dd <= c_d;
//stage 3
p <= a_dd * b_dd;
c_ddd <= c_dd;
//stage 4
r <= p + c_ddd;
tishi
Actually, it is very easy to implement o <= c±in1*in2
the below code works, vivado just fail to infer.
`timescale 1ns / 10ps // timescale time_unit/time_presicion
module test(
    input wire clk,
input wire rst,
input wire sub,             //0=add,1=sub
    input wire signed [24:0] in1,
    input wire signed [17:0] in2,
    input wire signed [47:0] c,
    output wire signed [47:0]  o,
    output wire signed [29:0] acout,
    output wire signed [17:0] bcout,
    output wire [3:0] carryout,
    output wire [3:0] carrycasout,
    output wire signed [47:0] pcout
DSP48E1 #(
.A_INPUT("DIRECT"),
.B_INPUT("DIRECT"),
.USE_DPORT("FALSE"),
.USE_MULT("MULTIPLY"),
.USE_SIMD("ONE48"),
.AUTORESET_PATDET("NO_RESET"),    // "NO_RESET", "RESET_MATCH", "RESET_NOT_MATCH"
.MASK(48'h3fffffffffff),          // 48-bit mask value for pattern detect (1=ignore)
.PATTERN(48'h000000000000),       // 48-bit pattern match for pattern detect
.SEL_MASK("MASK"),           // "C", "MASK", "ROUNDING_MODE1", "ROUNDING_MODE2"
.SEL_PATTERN("PATTERN"),          // Select pattern value ("PATTERN" or "C")
.USE_PATTERN_DETECT("NO_PATDET"),  // Enable pattern detect ("PATDET" or "NO_PATDET")
// Register Control Attributes: Pipeline Register Configuration
.ACASCREG(0),            //
.ADREG(1),               // Number of pipeline stages for pre-adder (0 or 1)
.ALUMODEREG(0),          // Number of pipeline stages for ALUMODE (0 or 1)
.AREG(0),                 // Number of pipeline stages for A (0, 1 or 2)
.BCASCREG(0),            // Number of pipeline stages between B/BCIN and BCOUT (0, 1 or 2)
.BREG(0),                         // Number of pipeline stages for B (0, 1 or 2)
.CARRYINREG(0),                   // Number of pipeline stages for CARRYIN (0 or 1)
.CARRYINSELREG(0),                // Number of pipeline stages for CARRYINSEL (0 or 1)
.CREG(0),                         // Number of pipeline stages for C (0 or 1)
.DREG(0),                         // Number of pipeline stages for D (0 or 1)
.INMODEREG(1),                    // Number of pipeline stages for INMODE (0 or 1)
.MREG(0),                         // Number of multiplier pipeline stages (0 or 1)
.OPMODEREG(0),                    // Number of pipeline stages for OPMODE (0 or 1)
.PREG(1)                          // Number of pipeline stages for P (0 or 1)
DSP48E1_inst (
// Cascade: 30-bit (each) output: Cascade Ports
.ACOUT(acout),                   // 30-bit output: A port cascade output
.BCOUT(bcout),                   // 18-bit output: B port cascade output
.CARRYCASCOUT(carrycasout),     // 1-bit output: Cascade carry output
.MULTSIGNOUT(),       // 1-bit output: Multiplier sign cascade output
.PCOUT(pcout),                   // 48-bit output: Cascade output
//这些引脚空着就好
// Control: 1-bit (each) output: Control Inputs/Status Bits
.OVERFLOW(),             // 1-bit output: Overflow in add/acc output
.PATTERNBDETECT(),        // 1-bit output: Pattern bar detect output
.PATTERNDETECT(),   // 1-bit output: Pattern detect output
.UNDERFLOW(),           // 1-bit output: Underflow in add/acc output
//这些引脚也空着,没用
// Data: 4-bit (each) output: Data Ports
.CARRYOUT(carryout),                               // 4-bit output: Carry output
.P(o),                           // 48-bit output: Primary data output
//P输出48bit的
// Cascade: 30-bit (each) input: Cascade Ports
.ACIN(30'b0),                     // 30-bit input: A cascade data input
.BCIN(18'b0),                     // 18-bit input: B cascade input
.CARRYCASCIN(1'b0),              // 1-bit input: Cascade carry input
.MULTSIGNIN(1'b0),         // 1-bit input: Multiplier sign input
.PCIN(48'b0),                     // 48-bit input: P cascade input
//这些引脚很重要,做流水线时,数据又这几个引脚输入。
// Control: 4-bit (each) input: Control Inputs/Status Bits
.ALUMODE(sub?4'b0011:4’b0000),  // 4-bit input: ALU control input
.CARRYINSEL(3'b0),         // 3-bit input: Carry select input
.CLK(clk),                       // 1-bit input: Clock input
.INMODE(5'b0),                 // 5-bit input: INMODE control input
.OPMODE(7'b0110101),                 // 7-bit input: Operation mode input
// Data: 30-bit (each) input: Data Ports
.A(in1),                           // 30-bit input: A data input
.B(in2),                           // 18-bit input: B data input
//.C(48'hffffffffffff),              // 48-bit input: C data input
.C(c),              // 48-bit input: C data input
.CARRYIN(1'b0),                      // 1-bit input: Carry input signal
.D(25'b0),                           // 25-bit input: D data input
// Reset/Clock Enable: 1-bit (each) input: Reset/Clock Enable Inputs
.CEA1(1'b0),                      // 1-bit input: Clock enable input for 1st stage AREG
.CEA2(1'b0),                      // 1-bit input: Clock enable input for 2nd stage AREG
.CEAD(1'b0),                      // 1-bit input: Clock enable input for ADREG
.CEALUMODE(1'b0),                 // 1-bit input: Clock enable input for ALUMODE
.CEB1(1'b0),                      // 1-bit input: Clock enable input for 1st stage BREG
.CEB2(1'b0),                      // 1-bit input: Clock enable input for 2nd stage BREG
.CEC(1'b0),                       // 1-bit input: Clock enable input for CREG
.CECARRYIN(1'b0),                 // 1-bit input: Clock enable input for CARRYINREG
.CECTRL(1'b0),                    // 1-bit input: Clock enable input for OPMODEREG and CARRYINSELREG
.CED(1'b0),                       // 1-bit input: Clock enable input for DREG
.CEINMODE(1'b0),                  // 1-bit input: Clock enable input for INMODEREG
.CEM(1'b0),                       // 1-bit input: Clock enable input for MREG
.CEP(1'b1),                       // 1-bit input: Clock enable input for PREG
.RSTA(rst),
.RSTALLCARRYIN(rst),
.RSTALUMODE(rst),
.RSTB(rst),
.RSTC(rst),
.RSTCTRL(rst),
.RSTD(rst),
.RSTINMODE(rst),
.RSTM(rst),
.RSTP(rst)
endmodule
module bitstream_tb;
reg rst;
reg dec_clk;
reg           subadd;
reg signed [24:0] a;
reg signed [17:0] b;
reg signed [47:0] d;
reg signed [47:0] c;
wire signed [47:0] p;
wire signed [29:0] ac;
wire signed [17:0] bc;
wire [3:0] co;
wire [3:0] ccas;
wire signed [47:0] pc;
initial begin
    rst = 0;
    #200 a = 10;
    #0 b = 20;
    #0 d = 45;
#0 c = 400;
#0 subadd = 0;
#2 subadd = 1;
    #50 rst = 1;
    #1 rst = 0;
    #100 $display("p %d",p);
end
always
begin
    #1 dec_clk = 0;
    #1 dec_clk = 1;
end
test test_inst(
.clk(dec_clk),
.rst(rst),
.sub(subadd),
.in1(a),
.in2(b),
.c(c),
.o(p),
.acout(ac),
.bcout(bc),
.carryout(co),
.carrycasout(ccas),
.pcout(pc)
endmodule
varunra
Hi @tishi ,
According to UG901
so for your code with out attribute vivado infers single DSP(confirmed with vivado 18.3) .
