hosemann
XPM_MEMORY warning "[Vivado 12-180] No cells matched 'get_cells ..." during synthesis
during synthesis of XPM_MEMORY i get the following warning message:
WARNING: [Vivado 12-180] No cells matched 'get_cells -hier -filter {PRIMITIVE_SUBGROUP==LUTRAM || PRIMITIVE_SUBGROUP==dram || PRIMITIVE_SUBGROUP==uram || PRIMITIVE_SUBGROUP==BRAM}'. [/home/tools/vivado/Vivado/2019.2/data/ip/xpm/xpm_memory/tcl/xpm_memory_xdc.tcl:3]
I know it is a false warning (it is not affecting my design).
I found some other posts related to the warning:
https://forums.xilinx.com/t5/Synthesis/Warnings-and-critical-warnings/m-p/849517/highlight/true#M25774
https://forums.xilinx.com/t5/Design-Entry/Constraining-error-in-XPM-madule/m-p/984553#M20786
As these posts are 2 years old and it is Vivado tool related
Are there any plans to fix this?
 Thomas
anusheel
@hosemann
Can you please share the XPM instantiation file which is resulting in this false warning and I will test the RTL in latest internal build to see whether this is already fixed or not. If not, I will be filing a new CR for this issue.
Anusheel
hosemann
Hi Anusheel,
find attached a simplified Vivado project including the synthesis log showing the warning message (i add .txt to make the upload work). It looks like the property PRIMITIVE_SUBGROUP is not jet available when the constraint file read.
  Thomas
hosemann
Hello Anusheel,
any news on that topic?
  Thomas
