XST - configuration - VHDL
Dear all,
In my current project I have an entity for which I which arhitecture to use on a VHDL file where I instantiate the entity, like following configuration code:
-- Embedded configuration
-- Select control architecture to use
for all : Ctrl2D use entity work.Ctrl2D(rtl_small);
Within the VHDL file where Ctrl2D is defined, I have different configurations, namely rtl_tiny and rtl_small. Within each of those, are processes which have variables whose length depend on some constants (KA, KB), like:
process_out : process (in_a, in_b)
    variable var : std_logic_vector (KA-KB-1 downto 0)  := (others => '0');
  begin
I should select which architecture to use in the configuration (rtl_tiny or rtl_small) depending on a given a given set of values KA and KB. For a set of values KA and KB that works fine with rtl_small and having rtl_small selected in the configuration, XST, when parsing, gives me warnign and error messages:
Entity <Ctrl2D> compiled.
WARNING:HDLParsers:3350 - "D:/Projects/Ctrl2D.vhd" Line 157. Null range: -33 downto 0
ERROR:HDLParsers:804 - "D:/Projects/Ctrl2D.vhd" Line 214. Size of concat operation is different than size of the target.
Entity <Ctrl2D> (Architecture <rtl_small>) compiled.
But those lines (157 and 214) are within the architecture rtl_tiny, not rtl_small.
I was confident that by selecting the right architecture in the configuration I was completely bypassing everything related to non-desired architectures, but it seems like I was wrong.
How can I direct XST to ignore the code of the non-interesting architectures, and parse and synthesize only the one that I selected in the configuration?
Thanks a lot in advance,
JaaC
Hi JaaC,
XST supports configurations during the declaration of the component and not through the configuration block:
for <instantation_list> : <component_name> use <LibraryName>.<EntityName(<ArchName>);
or, in a slightly more readable format:
for all : NAND2 use entity work.NAND2(ARCHI);
- reference page 380 of the XST User Guide 12.3 version.
Dear elzinga,
Thanks for your reply. I had already read that info from XST UG, and did not help at all. My code is already in the declarative part of the architecture, see:
architecture struct of Stack2D is
  -- Interconnection signals
  signal dat_2ext : buf2dwrd;
  signal rd_2ext  : std_logic;
  signal dat_2slv : buf2dwrd;
  signal wr_2slv  : std_logic;
begin
What was not metioned is that pragmas had to be added, like this:
-- pragma synthesis on
  -- pragma synthesis off
Now everything works flawlessly.
Kind regards,
JaaC
Hmm, something else is happening becasue the statement:
Only tells the tool (XST in this case) to start treating the following code as synthesizable.  Generally, the pragmas are written as:
.... code not synthesized
This is so you can call in code that is meant only for simulation.  In the code snippet that you have provided, you are telling the tool to stop syntheiszing after your:
However, the format of your pragmas I believe is a remnant of XST and the documented way to turn of and on the synthesis tool is to us the following:
-- synthesis translate_off
-- synthesis translate_on
I suspect that there is something else going on with your code.
I had not written the _ (underscore) correctly, the code I have is:
-- pragma synthesis_off
for all : Ctrl2D use entity work.Ctrl2D(bighalf);
-- pragma synthesis_on
And this, mixed with having each different architecture for the same entity in a different file, and including only the required architecture file, seems to work.
My concern now is that I will need to include different architectures, something in the lines of:
for Inst_0 : Ctrl2D use entity work.Ctrl2D(bighalf);
for Inst_1 : Ctrl2D use entity work.Ctrl2D(bigfull);
and so on.. I'll give it a try, and see what happens. If someone can ahead of time point to some correct way of doing this that I am overlooking, I would be very grateful.
JaaC
