Visitor houandreas
Xst:1336 - (*) More than 100% of Device resources are used
hi, I'm using SP601 board with xc6slx16-2csg324.  But I get a warning "Xst:1336 -  (*) More than 100% of Device resources are used". the Device Utilization Summary is here
The only one that over used is DCMs. But xc6slx16 should support 4 DCMs and I only used one. And the Available mount it shows is 0. That's weird. This project was programmed on Spartan 3 and I just move it to Spartan6. Could it be the cause?
Re: Xst:1336 - (*) More than 100% of Device resources are used
If you are using primitive instantiation in your code and there is nothing to match it up in the other device ISE stops there (much like Vivado actually). Say you used DCM_ADV in S3, but in S6 the equivalent is named DCM_ADV2, then you have to match up the name for S6. Also check anything that was produced from CoreGen.
See ug382 in chapter 2 table 2-3, inS6 it's named DCM_SP.
Visitor houandreas
thanks. I regenerated the DCM block and the problem is gone
