Carlos0u0
Xst:2999 - Signal 'rom_0_0_0', unconnected in block 'rom0_0_0', is tied to its initial value.
Why do I encounter this problem?Or can I ignore this message?
`timescale 1ns / 1ps
module rom0_0_0(out,addr,command,clk_match,enable,select_mod);
output out;
input addr,clk_match,enable,select_mod,command;
parameter ROM_WIDTH = 36;
parameter ROM_ADDR_BITS = 9;//2^n can cover the amount of this stage
(* ROM_STYLE="BLOCK" *) //(* ROM_STYLE="DISTRIBUTED" *) or (* ROM_STYLE="AUTO" *)
reg [ROM_WIDTH-1:0] rom_0_0_0 [511:0];
reg [ROM_WIDTH-1:0] out;
wire [ROM_ADDR_BITS-1:0] addr;
wire [1:0] command;
wire select_mod;
initial
$readmemb("Data/Module0/StageR1_0", rom_0_0_0, 0, 511);//0~ n-1 for the amount
always @(posedge clk_match)
begin
    if (enable)
    begin
        if (command==2'b00)
        begin
            if(select_mod==1'b1)
            begin
                out <= rom_0_0_0[addr];
            end
            else
            begin
                out <= 0;
            end
        end
    end
end
endmodule
varunra
hi @Carlos0u0,
I am quite not sure which version of vivado you are using.
the message you mentioned is it a warning or error or critical warning ???
I tried the above mentioned code and its tools was inferring Block ram.
Make sure the mem file correctly. missing mem file may lead to the issue
Carlos0u0
hi @varunra
Thank you for your reply.
The tool I use is ISE 14. 7.
The above message is just a warning.
And I also confirmed that the mem file is in the file path. So I want to ask if this warning can be ignored?
varunra
HI Carlos0u0,
I am using the same version of ISE. The only difference between your code and my code is, I have given the complete path path to my the mem file.
Can you try the following.
1. If you are using a xst project try copying the mem file to the location where the the design file(i.e both the design file and mem file should be in same directory) is and just give the mem filename like
$readmemb("<memfile_name>", rom_0_0_0, 0, 511);//0~ n-1 for the amount.
2. is this is not possible try giving the absolute path in $readmemb command.
Let me know if that helps
Carlos0u0
hi @varunra
Thank you for your reply, I will try your method.
If it is useful, I will reply to you again.
