add same file in two different library like work and another xyz lib
i want to add same vhdl/verilog library file in two different libraries in vivado synthesys using add_files XDC tcl command
Scholar jmcclusk
Re: add same file in two different library like work and another xyz lib
Vivado doesn't seem to support this from the gui.   but I was able to use TCL to "force" a list as the library property..  I would be very careful with this, because it MAY NOT WORK, and MAY BREAK THE COMPILE.
set_property library [list library1 library2 library3 ] [get_files  foo.vhd]
But I should remind you..  work is not a "real" library...  just the local working set.
Be careful with this, and please report if this actually works.
Scholar richardhead
Although this should be possible from a VHDL perspective, the main question is why?
Why not just have the entity in one library and have it called from another file using the original library?
Newbie suraj.kole
it is for keeping separate libraries for simulation and synthesis.
Newbie suraj.kole
it is not working...
it i set to 2nd library, it is deleting from 1st one...
