adder2/adder3/adder4 synthesis using ISE
I have observed during synthesis of higher adders(width great than 5 or so) (adder5 and upwards) Xilinx uses carry chain but for adders with width 4 or less it just uses LUTs and no carry chains.
Has anyone else observed this? Any reasons
Is there a way to force it to use carry chain???
I would appreciate if someone could look at it and reply.Thanks
I don't have the exact reason but I think it is due to a balance of resource utilization and timing performance.
When the adder is small, using LUTs results in less utilization and the performance is good enough.
Why not just have XST to choose what resources to use?
Is there any special reason that you'd like to force using carry chain for small adders?
Vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
@nomita,
I believe there must be an internal threshold defined in the XST to decide when to infer adders with carry chains, which can be tested with a small test case as already mentioned by you.
As already mentioned by Vivian, let the tool take decision on logic inference.
However, if you want to force the inference, please use use_carry_chain attribute on the signal declaration. This will push the logic into the carry chains.
Anusheel
Helpful answer -> Give Kudos
