Newbie vyella1
bram's synthesizing as lutram's at high frequency
Hi ,
I am doing synthesis for an encoder design and at lower frequencies the memories portion of the design is synthesizing as BRAM's, but when I am running the same design at higher frequencies (above 400MHz onwards) the same memory portion of the design is getting synthesized as LUTRAM's. Can you suggest me any method or any VIVADO command where I can avoid the memory portion of my design not getting synthesize as lutram's at higher frequencies.
Thank you,
Vamsi
Re: bram's synthesizing as lutram's at high frequency
@vyella1
Did you try using RAM_STYLE attribute to push the logic in BRAM?
Anusheel
Anusheel
@vyella1
Anusheel
Anusheel
Newbie vyella1
Hi anusheel,
I tried using it and it is not working, but when I synthesized on a different chip the memory is synthesizing as BRAM's only at higher frequencies also.
