Voyager
Voyager
does "initial" synthesize to a value?
I am using ISE 14.2 and am programming in verilog.  I have the following two lines in some code:
reg initializing;
initial initializing = 1;
 Does that synthesize the same way it simulates?  Meaning, upon powerup, does the register initializing have the value 1? It seems like it does, but I wasn't sure if I was getting luck and fooling myself.
Guide
Guide
Re: does "initial" synthesize to a value?
Yes. The initial value of the register is extracted (by FPGA synthesis tools ONLY - not ASIC tools) and is used as the INIT value for the flip-flop (assuming that the reg "initializing" ultimately becomes a flip-flop).
A better (more concise) way of doing it is
reg initializing = 1;
Avrum
Guide
Guide
Avrum
Voyager
Voyager
Thanks,  that does look clearer.
Just keep in mind that the INIT value is loaded at FPGA configuration.  It will not be loaded at functional reset (if your design contains one).
Seems obvious  - and it is - but sometimes can lead to perplexing behaviour if this distinction isn't kept in mind.
--Mark
Voyager
Voyager
Yes, I did realize that, but it is a good point to make!
Anonymous
Not applicable
I also have the same question before ,and all our team member use "initial" to initialize the register.
