fixed vs float resource usage
Synthesized a (32 x 32) multiplier ip,
mul construction - using LUTs
optimization option - speed
pipeline stages - 6
Also synthesized a 32 x 32 floating point ip
with no dsp usage.
Design run displays:
 LUTFF
float 32626681
fixed 3211021143
Is this justified that fixed point is taking more
resource than float operation.
Also, how do I use multiplier ip for fixed point case
and for integer case?
(Am a starter w.r.t Xilinx Vivado and FPGA architecture)
Many thanks in advance,
Varsha
Scholar jmcclusk
Re: fixed vs float resource usage
Floating point actually only has a 24 bit mantissa, so you only get a 24x24 multiplier with floating point,  while 32 bit integer data generates a true 32x32 multiplier.   So these LUT usage results are quite possible.
Scholar jmcclusk
Thank you for the reply, it helped a lot :)
I have another question.
How do I customize the multiplier ip
between fixed and integer type?
Is it that customizing the ip is the same for
fixed or integer type , but we interpret the
decimal point location?
Varsha
Scholar richardhead
@varshajhapillai
Fixed arithmatic is really just integer arithmetic. The separation between integer and fractional part is really just a fixed offset in the value (ie. shift left by N bits before calculation then shift right by N after calculation). This shift is basically free in FPGAs.
Thank you so much, that makes it clear :)
