generating DCP from a user managed ip
Accepted Solution Solved
Accepted Solution
I am using a 6-lane Aurora 8b10b core in Vivado 2017.2.  I need to assign the lanes to specific GT's, which are different than the default.  With the default, I get errors saying that the QPLLCLK and QPLLREFCLK are not in the right quads.  This is true, but a simple mod to the  multi_gt.vhd file can correct the problem.
I have applied set_property IS_MANAGED false to the IP core, and I was able to modify the file as suggested in
AR# 57546.  However, I cannot regenerate the DCP file.   In the Design Runs tab, it indicates that the core is "using cached IP results"
If I elaborate the design, I still see the original connectivity, without my change.
If I try to regenerate output products, I get a message stating that the core is locked (which it is).
AR# 57546 suggests selecting the IP in the design runs window, and performing "launch runs", however this doesn't seem to be possible in 2017.2.
How can I regenerate the DCP and pick up the change in the core?
Thanks, Ed
Re: generating DCP from a user managed ip
Hi @eflaherty
>>The IP does not have the _synth extension as stated.   I've tried reset_run with and without the extension, but I get this:
reset_run  aurora_core_hub1
ERROR: [Common 17-162] Invalid option value specified for '-run'.
This is happening because your OOC runs are using IP cache results.
Before editing the IP, using IS_MANAGED flow mentioned in UG896 latest, page 108, please try the below steps:
1)In Vivado GUI go to Settings-->IP-->Clear_cache
2) Then in the source window, select the IP and right click-->Reset output products. Then again right click--> Generate output products.
3) Once this is done, please follow the IS_MANAGED flow as per UG896,page 108.
Hope this help.
Rohit
All Replies
from the latest UG896 pg 108:
5. Re-create the IP output products, including the DCP, as follows:
a. Reset the IP OOC run. This has to be performed using the Tcl Console. Look at the
Design Runs tab in the Out-of-Context Module Runs folder, and find the IP where you
set the IS_MANAGED property to FALSE, with the name <IP_Name>_synth_1.
Execute the following command in the Tcl Console to reset the run:
reset_run <ip_name>_synth_1
Any ideas would be welcome....
Hi @eflaherty
Hope this help.
Rohit
That worked perfectly!
Thank you very much.
Ed
