how to generate edif of sub module?
how to generate edif of sub module?I use vivado 2017.4
        I want to generate edif for some submodule of my project.So that others can continue to develop .
for instance, project like this
   TOP.V including
       |-----aaa.v
       |-----bbb.v
       |-----ccc.v
I use write_edif  only can generate the edif file for top.v . But I want to generate edif for aaa.v bbb.v ccc.v and keep top.v module as a .v file.
       thanks, what should I do?
You may want to keep hierarchy of the submodules and try "write_edif -cell" command. Refer to "write_edif -help" for the details.
@gg9132qq
You can also set these sub-modules as OOC for synthesis and then use their checkpoint file to write edif file.
Anusheel
