how to use timing limitation?
hello!
i want to learn how can i use timing limitaion in vivado but i can't find tutorial about that!
for example i have a circuit with 3 part, i need 100ns delay between part 1 and 2 in my circuit! how can i set this delay in vivado?
is there any tutorial for my question?
with thanks and regards.
Re: how to use timing limitation?
Hi @mohsenajorloo,
There are 2 things here. Are you trying to add delay between two paths or override the setup and hold analysis using set_max_delay?
Please go through https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_3/ug945-vivado-using-constraints-tutorial.pdf and https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_3/ug903-vivado-using-constraints.pdf for timing constraints.
Arpan
Hi @mohsenajorloo,
Arpan
Guide
Guide
If you are thinking of trying to use timing constraints to create a 100ns delay - don't....
First, 100ns is a VERY long delay for an FPGA - I doubt you could convince the router to add an intentional delay of that long.
Second, delays in a CMOS process (like the FPGA) vary significantly from part to part and over temperature and voltage. The "rule of thumb" variation is about 3:1, so if you want 100ns min, you will get almost 300ns max.
The way to manage time in an FPGA is through a clock. If you want certain things to happen 100ns apart, then make them synchronous (running on the same clock) and count off the correct number of clock cycles; i.e. 10 cycles of a 100MHz clock is 100ns.
Avrum
