moncefou
missing externel ports when trying to configure constraints
i made this design :
 the synthesis runs ok , but after that when i open the synthesised design to do the port mapping i cant find find all the ports some are missing :
kdeshwal
Hi @moncefou ,
Can you implement the design and check if you observe the similar issue?
I think it won't see it after implementation.
Kuldeep
Please give Kudo and Accept as a Solution if solution provided seems helpful.
Have a look at our Versal Design Process Hub, Versal Blogs and the Versal Forum Useful Resources
anusheel
Hi @moncefou
Are you managing the wrapper or Vivado? Please verify whether the wrapper file is updated or not with all the BD ouputs/inputs.
Anusheel
