silverace99work
"Ambiguous Clock In Event Control" synthesis error
Hi guys,  I've been getting the synthesis error in the subject title for a particular block (see below).
I understand that the error comes about when the sensitivity list of the always block makes it so that the synthesis tool is not sure how to connect things (as discussed here and here). However I cannot tell what is wrong in my case.
I've been using "always @(posedge clk or posedge rst)" all across my design and am only seeing the error on this very particular block. Can anybody tell me where I have erred? Thanks!
    always @(posedge clk or posedge rst) begin
        if (rst) begin
            frame1 <=  46'h1490416637ff;
            frame1_counter <= 'd46;
            frame1_start <= 0;
            frame1_end <= 0;
            frame1_out <= 1;
        end
        begin
            if (tx_en) begin
                if ((frame1_counter != 0) && transmit_point_reached) begin
                    frame1 <= {frame1[44:0], 1'b0};
                    frame1_counter <= frame1_counter - 1;
                    frame1_start <= 1;
                end
                else if (frame1_counter == 0) frame1_end <= 1;
                if (transmit_point_reached) frame1_out <= frame1[45];
             end
        end
    end
avrumw
Expert
Expert
You are missing the "else" between the "end" of your reset clause and the "begin" of your non-reset clause...
Avrum
avrumw
Expert
Expert
Avrum
anusheel
@silverace99work
Let us know if you have any further queries, else please close this thread by accepting above answer as an accepted solution.
Anusheel
silverace99work
Ahh, derp. Thanks avrumw!
