synth_design apparently getting stuck [Vivado 2012.4]
I am running Vivado 2012.4 32-bit on my 64-bit machine (because the 64-bit Vivado quits with an error every time I launch it. I read something about replacing some dll with a dll from a working machine. But this is the only machine I have access to.).
So the design is a mix of system verilog and verilog RTL. I have set those .v files as type "SystemVerilog". After that I was able to run Design Elaboration Successfully.
In the constraints file, I have simply put just the create_clock command.
The synthesis is running; I see the "Running synth_design" with the green progress bar on the top right but I am not seeing any progress on the log tab or any hard disk write activity.
This has been the case since about an hour. How do I know where that got stuck and how can I resolve it? Thanks!
Re: synth_design apparently getting stuck [Vivado 2012.4]
From the runme.log, I can see that it has got stuck at "Start Technology Mapping" stage in synthesis.
Could please try to run any example design with vivado.check whether you are facing the same issue or not.
Ankury
Re: synth_design apparently getting stuck [Vivado 2013.2]
Seems like a similar issue - Vivado just "runs" synth_design - no errors, no warnings beyond this.  Attached is the runme.log - sits here forever with no indication as to why.
Please help.
David.
Hi David,
Can you please share the project Archive so that i can check the details and get back to you?
What is the -flatten_hierarchy value in your project settings ?
Can you try using the value full/none and see if this helps?
Achutha
