vcc and GND signals
hi
when using signals with the following names،( in ISE) their color comes in red. why?
signal GND,VCC      : std_logic;
Re: vcc and GND signals
@fpgaamoz
When the design uses constant1 and constant0 then tool connects such logic/nets to the VCC and GND respectively.
Anusheel
Helpful answer -> Give Kudos
Community Manager
Community Manager
Those are unisim/simprim reserve words. In ISE Text Editor, you have the color code for text based on the words. Please refer to https://www.xilinx.com/support/documentation/sw_manuals/xilinx11/ite_r_text_color_coding.htm for more details on this.
thak you for your reply. i had another question. VCC and GND is used to what to do?
@fpgaamoz
Anusheel
