verilog MSB and LSB
I would like to know wich is the MSB and LSB of the following two verilog vectors
.an_adv_config_vector({1'b0,1'b0,1'b1,2'b00,2'b10,1'b0,2'b00,1'b0,1'b1,4'b0000,1'b0})
.link_timer_value(9'b100111101)
Thank you!
Guide
Guide
Re: verilog MSB and LSB
The most significant bit is always the leftmost bit.
Avrum
Guide
Guide
Avrum
