Anonymous
Not applicable
vhdl-93 in vivado
Does anybody know how to set the vhdl-93 option in Vivado 2013.1 ?
In ISE, there was the possibility to set the "VHDL Source Analysis Standard" property to "VHDL-93".
In Vivado, I didn't find any way to set this option.
Unfortunately ISE is not an option because I have a gated clock design, which I need to translate with
the "gated_clock_conversion" option, which is only available in Vivado.
So does anybody know how to set the vhdl-93 option in Vivado ?
dak_zach
I got my problem figured out, hopefully it's the same problem that andre.bischof had.  I probably should have noticed it sooner, but it all makes sense now.  I have been writing in VHDL, but I am calling a Verilog module (a file from an IPCore) and Vivado does not yet support mixed-language direct instantiation (http://www.xilinx.com/support/answers/47454.htm).  The answer record basically tells you that you have to declare the Verilog component in VHDL.
The answer record also says that they will revisit this types of mixed-language issues if there are enough requests in the future.
I still have my Webcase open, and am asking which version of VHDL Vivado uses since I can't find it listed anywhere.  I'll post the answer if I get anything back.
viviany
Do you encounter any problem synthesizing your VHDL code?
Vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
Anonymous
Not applicable
Yes I got problems with the instantiation of components, for example:
  i_addsub_to_flat : entity dware_lib.addsub
    generic map (width => 3*(half_width+2)+half_width)
    port map (
      a       => l51_addsub_a_interleaved,
      b       => l51_addsub_b_interleaved,
      ci      => l51_addsub_ci_ll,
      add_sub => '0',
      sum     => l51_addsub_sum_interleaved,
      co      => l51_addsub_co_uu
Vivado complains about using the constant '0' in the port map,
and the instantiatin without component declaration (both marked red).
Both are vhdl-93 features, which is no problem in ISE, but gives errors in Vivado.
I have to map a huge design on the FPGA so modifying all code to vhdl-87 style is not an option.
viviany
I'll check this and get back to you.
Vivian
viviany
Can you post the error messages from Vivado?
Vivian
Anonymous
Not applicable
for using a constant '0' in the port map, I get the error message:
[Synth 8-2396] near character '0'; 3 visible types match here
Anonymous
Not applicable
for instantiating without component declaration, I get the error message:
[Synth 8-493] no such design unit xxxxxxxxx
Anonymous
Not applicable
Please find a simple test case attached.
In test87.vhd, component instantiation and port mapping are done in vhdl-87 style.
This code synthesized without any errors.
In test93.vhd, component instantiation and port mapping are done in vhdl-93 style.
There are the following errors:
ERROR: [Synth 8-2396] near character '0' ; 3 visible types match here
ERROR: [Synth 8-493] no such design unit: blk
Are you really sure that Vivado supports VHDL-93 by default ?
bassman59
Historian
Historian
Hopefully it supports by default a version that's a lot less ancient than VHDL'93! It is, after all, 2013. it should do VHDL-2008. Read the synthesis guide to be sure.
Anonymous
Not applicable
Please take your time and try to synthesize the simple expample code I attached to my previous post,
and you will see that Vivado cannot handle the VHDL-93 example.
It surprises me that ISE can handle it, but not Vivado ...
dak_zach
I am also experiencing the same problem.
When I put a constant in the port map, I get the error:
With a signal in the port map is assigned a constant, I get the error:
[Synth 8-493] no such design unit XXXX
It basically looks the same as in andre.bischof's test file.  It would be helpful if anyone could answer if there is an option to choose which VHDL version is being used.  All of the code that I've written is in VHDL-93, so changing it all over for Vivado is not an option.
brimdavis
I think what you are wrestling with is a library issue, not a language version issue.
The port errors are just a red herring caused when Vivado can't find the entity.
How are you telling Vivado to find your 'dware_lib'  ?
Your simple test case is missing the necessary library information needed for direct instantiation.
Either add a 'use work.blk' at the top, or change the instantiation to 'work.blk' instead of just 'blk'
It then will compile with Vivado 2013.2
-Brian
dak_zach
I've been fighting this problem for a couple days now and just finally got through synthesis without any errors or critical warnings related to this problem (just updated to 2013.2, but that didn't help with this error).
It seemed like the compiler didn't know about the design I was trying to instantiate, but it was showing up in the hierarchy.  Vivado originally had the "Hierarchy Update" set to "Automatic Update, Manual Compile Order", so maybe it was compiling my top level before any of the lower levels, but setting it to Automatic Update and Compile Order didn't change anything.
I eventually got it to synthesis by declaring my components rather than instantiating with the entity library.
instead of:
uut : entity work.test
port map(
in1 => signal1,
out1 => signal2
use:
component test is
port(
in1 : in std_logic;
out1 : out std_logic
end component test;
begin
uut : test
port map(
in1 => signal1,
out1 => signal2
end;
Correct me if I'm wrong, but VHDL-93 added in the functionality to instantiate based on the library rather than declaring the component.  From that, it seems like Vivado is using VHDL-87.  I couldn't find anything in the synthesis guide about which version of VHDL is being used.  VHDL-2008 was suppose to be supported in 2013, but got moved back to 2014 (http://www.xilinx.com/support/answers/51502.html).  You would think they would support other versions like 93 or 2002 before going to 2008.  If anyone actually knows what version of VHDL Vivado uses or if it can be changed, it would be really helpful to know.
bassman59
Historian
Historian
Well, that's totally fscking borked that a synthesis tool in 2013 cannot deal with direct instantiations.
File a WebCase and let's see what Xilinx has to say about it.
bassman59
Historian
Historian
Having said that, it does seem like it's an order-of-compilation issue, and if the tools can't figure out the hierarchy then they're borked because this has been working in ISE since basically forever.
viviany
Does it help if you set test.vhd as global included by right-clicking the file?
Vivian
dak_zach
I had tried setting the file to a global include before, and I got the same errors.
One thing I did omit from a previous post was the whole error message, but andre.bischof included the whole thing:
It seems like since it hasn't compiled the file and therefore doesn't know the inputs/outputs, it is trying to decide if the constant '0' is a std_logic, std_ulogic, or a bit.  That would align with what I'm thinking, that it is either a VHDL-93 problem, or a compilation order problem.
I'll open up a webcase and see if we can get anywhere on it.
viviany
It'll be helpful for others if you can post the final conclusion of this issue from the Webcase in this thread. Thanks.
Vivian
Anonymous
Not applicable
I agree it really looks like a  compilation-order problem.
With the simple test case (test.vhd), I tried the following:
* After setting "automatic compilation order", I checked the "compile order" tab.
  The order looks ok: sub block first, then the top block.
  However, I get the error messages mentioned before.
* After setting "manual compilation order", I manually specified the compilation order:
  sub block first, then the top block.,
  I still get the same error messages.
I guess if it was a compilation order problem, it would have been resolved by manually setting the correct order ...
brimdavis
Please see my post of 06-26-2013
I tried your test93.vhd example in 2013.2; once the missing library information is provided for the direct instantiation, it compiles successfully.
I also tried several other small designs using direct instantiation with no issues seen.
-Brian
dak_zach
ed_xilinx
I had the same synthesis error
related to the use of a constant '0' in the port map,
That was "only" due to the corresponding vhdl file missing in the project !
Of course Vivado gave me this strange error message instead of simply reported for the missing file ...
dak_zach
I got the VHDL version currently supported in Vivado from the Webcase.  Vivado 2013.2 currently supports VHDL IEEE-STD-1076-1993 as well as floating and fixed point packages from VHDL 200x.   Hope that helps out someone in the future.
typhoonwa
I have a very similar problem in Vivado 2013.2 but can't solve it in the way described above. Specifically, I have an IP block (a FIFO queue) which doesn't get recognized by the tool. I get the error:
[Synth 8-493] no such design unit 'input_queue'
Despite the fact that I have declared the component:
COMPONENT kvs_ht_FIFO_Hash_FuncIn97
  PORT (    clk     : IN STD_LOGIC;
            rst     : IN STD_LOGIC;
            din     : IN STD_LOGIC_VECTOR(96 DOWNTO 0);
            wr_en   : IN STD_LOGIC;
            rd_en   : IN STD_LOGIC;
            dout    : OUT STD_LOGIC_VECTOR(96 DOWNTO 0);
            full    : OUT STD_LOGIC;
            empty   : OUT STD_LOGIC);
END COMPONENT;
and instantiate correctly:
     input_queue : kvs_ht_FIFO_Hash_FuncIn97
       port map (clk    => clk,
                 rst    => rst,
                 din    => buffInData,
                 wr_en  => resizeValidArray(X),
                 rd_en  => funcInReady(X),
                 dout   => funcInData(X),
                 full   => buffFull(X),
                 empty  => buffEmpty(X));
am I missing something here? Or is it some limitation in Vivado synthesis?
I am trying to get a MicroZed board up and running with Vivado 2013.2.
I have VHDL as the primary flow language, but the heirarchy is showing Verilog GND component with red question mark.
Synthesis is moaning and strips the design out.
This sounds like the same problem.
Can anybody verify this please?
( Incidentally : dont try the spell checker here ! it doesnt even know VHDL or Vivado!)
Mike
kaustin87
I am running into this same error in Vivado 2013.4 with the PCS/PMA IP for 10GbE:
  • [Synth 8-493] no such design unit 'ten_gig_eth_pcs_pma_wrapper' [ten_gig_eth_pcs_pma_v4_1.vhd:305]
The VHDL file is encrypted, and so is the wrapper. I added all the files manually to an RTL project. The files are included as sources. Any help would be appreciated.
driesd
Hi Kaustin87,
could you create a new thread? This thread is about Zynq and MicroZed in Vivado
When you do, can you report what error you are seeing?
In general, when working with IP in Vivado, you need to add the .XCI IP file, not the IP HDL sources.
The XCI will tell Vivado what the HDL files are, what libraries are used, which constraints and make a difference between HDL files for synthesis and files for simulation.
See UG896
Best regards,
Dries
Give Kudos to a post which you think is helpful and reply oriented by clicking the star next to the post.
hbaier
This problem
and the problem with  instantion  inst : entiy work.xxxx
are all caused if you have in the module you want to instatiate
use work.all;
I fighted for almost 20 hours until I removed use work.all from the modules.
--Heinz
penkovsky
Thanks for the tip, hbaier. Indeed, I had to remove "use work.all;" statements and manually include all the modules. Somethingis terribly wrong with Vivado :(
hbaier
and thank for your reponds
