Scholar pedro_uno
Re: vhdl-93 in vivado
What is the conclusion of the original thread?
I get the error below.  I see no solution in this thread. Please someone help.
ERROR: [Synth 8-2396] near character '0' ; 3 visible types match here
Here is my code snippet.
    sine_gen_inst: entity work.sine_gen
    Port map(
        reset         => '0', -- this causes the error.
        clk           => clk,
        next_data     => tx_next_data,
        i_data        => sine_i_data,
        q_data        => sine_q_data);
DSP in hardware and software
Scholar pedro_uno
I should have posted the full error message. It shows the synthesis tool going through several libraries finding different definitions of '0'.
ERROR: [Synth 8-2396] near character '0' ; 3 visible types match here [/path/design_name.vhd:115]
INFO: [Synth 8-1047] first match for ''0'' found here [./vhdl_packages/1993/src/standard.vhd:11]
INFO: [Synth 8-1047] another match for ''0'' found here [./vhdl_packages/1993/src/standard.vhd:20]
INFO: [Synth 8-1047] another match for ''0'' found here [./vhdl_packages/1993/src/std_1164.vhd:22]
I think it is a bug in the compiler.
Scholar pedro_uno
Actually, now I see what is happening here. I had not yet included my sine_gen module into the source list. Because of that the compiler did not yet know what type to use for the literal '0'.
It is a funny error message but now I know what to look for when I see it. Thanks.
Historian
Historian
Ah, a clue:
VHDL-93 did not allow using literals as the actuals in a port map. That was added in the 2002 update of the language. So if the synthesizer is following the strict VHDL-93 syntax, it should not even bother trying to determine the type of the actual. It should just error out.
Can Vivado be used in a VHDL-2002 or 2008 mode? That should work.
ERROR: [Synth 8-2396] near character '0' ; 3 visible types match here [file.vhd:n]
Why isn't this error message fixed? It is highly misleading.
I came across it again in 2016.2 when I forgot a 'use' clause for a library with a component instantiation. It is the component that Vivado can't recognize, the type is not the problem.
